I know the front valve cover gasket is leak and cam seal cap, but I think the crank seal is leaking. Also there was an oil drip on the tensioner. The is oil on the pan #1 seal, but I think that is from the crank seal leak, there is also oil on the a/c compressor and front of the oil pan, but thats looks like a combination of the front cam, valve cover gasket(2 years old) and crank seal leak.
What do you guys think?
If you're concerned that they're leaking, replace them all for your piece of mind
Well the sad thing is I replaced both cam seals and crank seal, valve cover gaskets(reused front one it was 2 years old. All replaced in December
I guess I just suck and I'll have to do them again. FML
That kind of leak can be really hard to find. I have something similar, no idea if it's the oil pan, oil filter adapter, or rear main. I've done literally everything else that can leak, so I guess the only way is to do the oil pan and oil filter gasket and hope it's not the rear crank seal. I sure hope not, this '93 has already kicked my ass enough.
__________________ 2000 Lexus ES300 Millenium Edition1MZ-FE 64,000 Km 1993 Camry V6 LE3VZ-FE 164,000 Km SOLD but still in the family 1990 Camry LE2VZ-FE 202,000 Km 1987 Camry LE3S-FE 435,000 Km 1971 Corolla 2-door Coupe2T-C 260,000 miles
Why not start with a power wash of all affected areas, run for a day or so and then take another close look and pics? Oil migrates all over the place, that might give you a better idea of exactly where its coming from and save you some maint. time. Just a thought, I'm guessing you have at least a week of leaking and moving/migrating around there. I trying to figure out where a leak from the other end of the engine is coming from myself. Looks like it come from just under the distributor, 1-2 drops daily after a days running.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Yup, I washed the engine twice, and the leaks appear in the same spot.
So, I'm ordering a front valve cover gasket and will replace that next week. I'm sure the crank seal is leaking too, but I want to be sure. Cringe at the fact the tb has to come off again.
Found the oil leaks at school. The front cam seal and crank seal is leaking.. I am replacing both cam seals, crank seal and the front valve cover gasket. The lip of the seal was damaged so it was pouring out oil onto the back of the timing cover. Thankfully the timing belt is dry and I am doing this at school.
dang... bad luck you have bro coming back to same things over and over. stick to OEM parts and follow installation instructions on everything to the letter...
Yeah, I suck with installing seals. Idk how it could have leaked from the cam seal, but that has already passed.
Yeah, ordered the parts, need to pick them up. I'm going to have my teacher install the seals, just incase. He said I was supposed to grease the seals so I wouldn't have torn anything. Wheel bearing grease or assembly lube is whats used on them.
Should be working on it tuesday and probably with finish wednesday or thursday as we have 2 hours of class.
So, today we took of the hardware and parts to get the the tb. BUT GOD DAMN the Bank 2 Cam pulley was ungodly tight. The breaker bar was about to snap in half. Rear one was easy, spanner wrench against the firewall, and popped it loose with the breaker bar.
Turns out he crank seal wasn't leaking, just the bank 2 seal and a little bit from the bank 1 seal. The bank 2 seal was completely destroyed, mangled the lip when I installed it the first time. It was pouring oil from there so it looked like it was the crank seal. Replaced both cam seals today and putting everything back together tomorrow. Valve cover gasket isn't leaking, but I might as well replace since I got a new one. Also going to clean the maf sensor, put dielectric grease on the the front coils and clean suspected connections and adjust cables.
No more oil leaks. I'm starting to know the engine inside out. Doing timing belts is like cake now. Especially with air tools.
Checking for what is making the front end popping noise, and the condition of the ball joints and tie rods. Also replacing the front valve cover gasket tomorrow in the shop, just because I already bought it.
Only have a few things left to do on my car:
Find mount causing D->R clunk.
Control arm bushings, or whatever is causing the front end to make popping sounds.
Reboot ps axle, ps leak increased wear on the inner boot, but just stress marks right now.
Replace starter contacts
Drop the trans pan. Replace the filter and clean the pan.
