Hi, guys. Need a few dash bulbs for my '98 Camry LE (4 cyl, auto). I actually think there might be a short somewhere, or, I think me monkeying with
other bulbs without removing battery cable/fuses causes certain bulbs to burn out (anyone know?).
So, these are the bulbs I need. Autostores around here are horrible so I want to order online. Also, for certain bulbs I want to get the LEDs so I'm looking for the size so I can order by number.
- Bulb 1 - Width across of connector is .363" (.922 cm). I found this under the center console-located shifter indicating park, drive, etc. I didn't have one so I stole this from the trunk, so I want a bright LED to replace that one. Is this a 194?
- Bulb 2 - .175" (.444 cm). Found 2 of these behind the heater dials with green caps on them. 74s?
- Bulb 3 - Connector is same size as bulb 2, but the bulb itself is thinner. This illuminates the ashtray.
- Bulb 4 - Illuminates cigarette lighter area. Again, the CONNECTOR is the same as bulbs 2 & 3, but the LENGTH of the bulb itself is shorter. This one wasn't burnt out but I broke it myself trying to look at it. It's a pain in the butt because you need to solder it alone with 2 metal connectors back into the plastic part. I'd love to just buy the whole plastic part but I don't know what it's called. HELP!
- Just something useless guy at AutoZone told me would fit.
If anyone knows please let me know. Thank you!
I'm going to make an interior light mod and post pics soon!
