Hey guys ive posted up 2 threads about the wiring diagrams for my vienta not many precise reply's so i thought id post up the wiring diagrams for everyone.
i had to connect a turbo timer so if anyone ever needs too it'll now be simple.
on our iginition connector there are 8 pins 3 on top and 5 on the bottom
we have 2 positive 12vs the beefy black with red stripe and the beefy brown.
the connections are
Beefy black with white stripe - starter motor
Beefy black yellow stripe - Ignition 2
Beefy Blue red stripe - Ignition 1
Beefy Brown white stripe - Acc or engine On
There is NO ground wire.
[For TT's with 4 connections] like Fet tb202-308
to connect the turbo timer you must ground your TT to the chasis
the TT red goes to either the iginitons Black red or beefy brown
the TT yellow goes with the iginitons Black with yellow stripe aka ig2
the TT Blue(or accesory) goes to the ignitons Brown with white stripe.
For TT's with 3 connections
Black Yellow and red.
Black to ground, red to 12v+ and yellow to Brown and white stripe
That should be it and working.
hope this helps someone else out
