running Light Issues! Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2011, 07:03 PM   #1 (permalink)
View DCWITT's Photo Gallery
ok this has been driving me crazy for weeks
my running lights have not been working at all and no fuses are blown but i still hear the clicking noise when i turn the switch and i checked all my connections and they are fine what could it be?!
if i were to describe my camry in one word i would choose freedom
DCWITT is offline   Reply With Quote
Old 02-26-2011, 07:43 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The clicking is normal. Have you checked the bulbs themselves by chance?
Old 02-26-2011, 08:01 PM   #3 (permalink)
yes all the bulbs are fine
and i know the clicking is normal it just means its not a fuse or relay
Old 02-26-2011, 08:11 PM   #4 (permalink)
hmm .. Well the only thing I could think is bad grounds if the bulbs are good, wiring is good, pigtails are good, pins inside pigtails are tight?
Old 02-26-2011, 08:17 PM   #5 (permalink)
yes i checked all plugs and they are tight i did notice one unplugged wire
the color is black and white but i cant find where it goes it might be a ground wire
Old 02-26-2011, 08:19 PM   #6 (permalink)
Could be.. Check it for voltage first, if it doesnt have voltage attach it to the body somewhere and see if your lights pop on. (Make sure the running lights are active when checking for voltage )
Old 02-26-2011, 09:39 PM   #7 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
Hmmm. this is a Canadian answer, so yours may not work the same way but. My DRL's seem to run off the high beam lights, at a reduced voltage. You say you have checked the bulbs, but do your high beams work? If not the problem is defininitely in your running light relay/fuse, wiring system
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 02-28-2011, 08:13 PM   #8 (permalink)
yes my high beams do work i will be replacing the relays this weekend
Old 02-28-2011, 09:24 PM   #9 (permalink)
View Novice_cardude's Photo Gallery
What all is not working? The click you hear is a relay, most likely for your low-beams. Do your dash lights come on when you turn the switch? Tail lights? License plate lights? If not, it's most likely a bad switch or open circuit in the light control circuit.
If those all come on and it's just the running lights (side markers?) that stay off, check out that circuit first.
Good luck!
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Tags
camry, gn 3, light, running, toyota
