Firing problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2011, 08:19 PM   #1 (permalink)
View deejayphilo's Photo Gallery
Firing problem
Got the timing perfect ....got new coil...got new cap and rotor...new timing belt....but the car not firing? It crank but not firing. Check the wires, got all firing order...test for current I just got shock with the current....pull the spark plug its SOAK with fuel so there is no problem with Fuel delivery.....any suggestion why not firing? I think I'll wait till the fuel evaporate from the intake coz I think its flooded but hope that's it...
deejayphilo is offline   Reply With Quote
Old 02-28-2011, 09:11 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Does your car have a crankshaft position sensor ? If so have you checked it ?
What fuel pressure are you getting? I know your getting fuel, but you didn't say how much pressure your getting.
What motor are you working with here?
What did you do before the car didn't start?
Old 02-28-2011, 04:29 PM   #3 (permalink)
No crank positioning sensor...i didnt get into measuring how much fuel yet...and d car is 2.2L....I did the timing belt and water pump...it crank and it seems like it wanted to fire but its not going thru...
Old 02-28-2011, 04:47 PM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
As usual tell us what color the spark is. Remove plug and attach plug wire, then touch plug threads to ground, have someone turn the engine over and see if the spark is bright blue - if not then you're not getting full voltage to plug.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-28-2011, 05:14 PM   #5 (permalink)
What will i do if am not getting enough voltage coz pretty much i change evrything....rotor, cap and coil..
Old 02-28-2011, 07:54 PM   #6 (permalink)
Either you're not getting full voltage to the primary of the coil or the coil is not putting out full secondary voltage. Engine needs air, fuel, compression, timing, spark. If you get bright blue spark then you're not getting one of the other ingredients. You'd have to recheck your work.
Old 03-01-2011, 11:44 AM   #7 (permalink)
Gameroom cash: $303755
"I think I'll wait till the fuel evaporate from the intake coz I think its flooded but hope that's it..."
If you have checked for a bright blue spark as noted above by several other posters, and still think you have a flooded engine, then hold your foor to the floor and crank the engine. That's how you start a flooded engine. This was true in the days of carburated engines and is still true today with modern fuel injected engines.
Mike
Old 03-01-2011, 12:29 PM   #8 (permalink)
What u mean hold your floor to floor then crank it...
Old 03-01-2011, 01:15 PM   #9 (permalink)
Sorry. Hold your foot to the floor on the gas pedal and crank it.
Mike
Old 03-01-2011, 01:55 PM   #10 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
You might have set the camshaft timing to the wrong mark. There are 2 and people mix them up sometimes.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 03-01-2011, 04:26 PM   #11 (permalink)
I already set timing twice to get it right and now i know am on d right timing...except d rotor not pointing to spark plug 1 on d right timing
Old 03-01-2011, 04:38 PM   #12 (permalink)
I don't think it's possible to install the distributor incorrectly, but something looks wrong. Which plug wire is it pointing to when engine mechanical timing set to TDC COMPRESSION? Have you checked ignition timing?
Old 03-01-2011, 06:17 PM   #13 (permalink)
Yah dats amazing coz it was pointing in between 1 -2...though d firing goes 1-3-4-2...if i have to time it based to where d rotor point at spark plug 1 it sounds bad cranking it and i know thats not how it sound for perfect timing...i put my timing on d cam sproket at the dot and hole..which is supposed to be on the v mark and hole...
