1998 Camry V6 Cali vs non Cali - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2011, 12:09 PM   #1 (permalink)
View gmoneyco's Photo Gallery
I have to replace the front Y-pipe/flex pipe/catalytic converter on my 98 Camry. The sticker under the hood says it conforms to US and State of California emissions standards. Does this mean it has California emissions? I've been pricing the replacement part, and it looks like the non-Cali part is SIGNIFICANTLY less $$ then the Cali part. Since the car is in MO, I'm not concerned about the emissions so much. I just wonder if the non-Cali part will fit, and if it does fit, I also wonder if its gonna through a CEL from the rear O2 sensor?
gmoneyco is offline   Reply With Quote
Old 02-28-2011, 02:17 PM   #2 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
This is a Federal label.
The CA label is a little different.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 02-28-2011, 02:39 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yes, yours is California compliant, if it says on emissions sticker.
If you need a better confirmation, just call the local dealer's Parts Counter and give them car's VIN# and they will tell you 100% answer.
Old 02-28-2011, 04:17 PM   #4 (permalink)
http://webpages.charter.net/gmoneyco/1998.jpg
Here's what mine looks like.
Old 03-01-2011, 05:07 PM   #5 (permalink)
98V6LE's Avatar
View 98V6LE's Photo Gallery
i'm going through the same thing right now.
i also have the Cali emissions and live in NY
the federal emissions pipe will NOT fit the Cali emissions vehicle(it's too short)..... trust me, i tried
off to spend more $ on the Cali emissions pipe....
good luck!
98V6LE is offline   Reply With Quote
Old 03-01-2011, 06:09 PM   #6 (permalink)
1MZ powered MR2
Most definitely a California emissions label. 2WU-TWC (pre-cats) and 2 A/FS (air-fuel ratio sensors).
I should have clarified, mine is a 50 state emissions label for the M/T models.
You'll definitely need the CA y-pipe. You can only use the Federal pipe with the Federal spec manifolds. The front exhaust manifold on your engine has a pre-cat built into it. The rear bank's pre-cat is built into the y-pipe, so the y-pipe has two catalysts in it, which makes it more expensive.
1991 Toyota MR2 V6
Tags
california emissions
