Originally Posted by stlwil
could be a cracked ignition coil .its in the dizzy under the cap
Really?... Did Toyota change the design from '92 to '93? On my '92, the coil's mounted to the driver's-side strut tower.
Where ever it is, that's good suspect to check out. Sometimes cracks are so small they're hard to see. So when it's warmed up and running rough, check your spark. Want to see a nice strong blue-white spark.
Originally Posted by tbss1
I got oe stuff.
Good! That takes those off the suspect list.
