Is there a neutral safety switch on manual 93 SE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2011, 09:51 AM   #1 (permalink)
View 1BADBAJA's Photo Gallery
Just as title says. Is there a neutral safety switch on the manual 92-93 MANUAL TRANSMISSION cars? If so which color?
1BADBAJA is offline   Reply With Quote
Old 03-02-2011, 09:53 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
Explain what you mean. I've not heard of "neutral switch". Maybe it goes by a different term.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 03-02-2011, 10:29 AM   #3 (permalink)
Automatics use a neutral safety switch so they don't start in gear. Some vehicles with a manual transmission also use them like some mazdas hondas and mitsu. Most bikes use them as well.
I just got through installing a 5701 viper and would prefer to use a neutral safety switch wire if there is one. I do not like the manual start initialization process but will use it if there is no neutral safety switch wire available. Safety is always 1st
Old 03-02-2011, 10:57 AM   #4 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
I thought that all Manual Toyota's didn't have them but after checking the catalog I had a listing (84540-32090), the EWD shows a black-white wire going to the ecm.
3VZFE MTM
Stevo_Echohb05 is offline   Reply With Quote
Old 03-02-2011, 10:58 AM   #5 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
No, but it uses a clutch start switch, which is right behind the pedal.
rusty9 is offline   Reply With Quote
Old 03-02-2011, 12:00 PM   #6 (permalink)
I have the clutch bypassed already and it starts fine when in auto mode mode just to test. I just didn't know if someone had a fsm and could check.
I will check the blk/wh wires at ecu unless anyone else has input.
Old 03-02-2011, 12:03 PM   #7 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Manual doesn't have a NSS. There's a clutch start switch, but if you've bypassed that, you're able to start in any gear without the pedal in...so just make sure you start in neutral only.
Chris Crash is online now   Reply With Quote
Old 03-02-2011, 12:51 PM   #8 (permalink)
Ok so 1 says there is one and 1 says there is none. Can anyone point me to a fsm?
Old 03-02-2011, 02:19 PM   #9 (permalink)
rusty9's Avatar
theres a split for A/T and M/T.
search for the es300 repair manual which deals with the 3vz, since the camry manual deals with the 1mz
