Axle Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 08:21 AM   #1 (permalink)
iTrader Score: -1 reviews
View Eric N's Photo Gallery
Axle Question
Well, i need to replace the driverside front axle in my coupe build. Its a standard, but Im fairly certain that i can use the axle from my old car? Just looking for some conformation.
Both have 5sfe, but my old car is an auto. I dont know the exact trannys though.
Thanks
1994 LE sedan & 1996 DX coupe....with a bit of SE thrown in there
Eric N is offline   Reply With Quote
Old 03-03-2011, 11:00 AM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I'm pretty sure there's a difference on the input shaft between the Auto and the Manual axles. I know the info is on this forum. Search.
RichieRichJP is offline   Reply With Quote
Old 03-03-2011, 01:05 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Won't work. The inner splines are different and/or the lengths are different.
'07 Honda Ruckus Big Bore
Old 03-03-2011, 07:19 PM   #4 (permalink)
Gah. Well thats a big bummer. Thanks.
Old 03-03-2011, 08:17 PM   #5 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my 93 camry 4cylinder manual transmission drive axle are interchangable with the 97 4cyl auto transmission.
but i think the V6 are different though
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 03-03-2011, 08:26 PM   #6 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
MY GOD. the auto axle will work, at the expense of your transimssion. Be prepared to re-do the tranny if you use an auto axle. I made this mistake. Just buy a new OEM axle from Gary...please.
Chris Crash is online now   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
Eric N (03-03-2011)
Old 03-03-2011, 08:29 PM   #7 (permalink)
I see. What happened?
And pardon my nubness, but who's gary?
Old 03-03-2011, 08:43 PM   #8 (permalink)
All my gear oil leaked out 200 miles away from home. Needless to say I had to ghetto rig it together to get it home and then pull the trans and inspect it.
Gary is the site sponsor from Toyota of Newman. He's got very good prices, I actually just ordered an axle for my 5 speed from him. It was only a couple hamiltons over aftermarket prices.
Old 03-03-2011, 08:51 PM   #9 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
^+1. Gary's a great guy to deal with. His board name is Toyotapartsman, or something close to that.
BMR is offline   Reply With Quote
Old 03-03-2011, 08:53 PM   #10 (permalink)
hmmm, that is very interesting
because before i swapped the axle i did compare the manual and auto axle, and they are identical for 4cylinder, and both tranny are still running fine after swapped.
the reason i swapped was because the my manual axle was torn, and i have a auto axle with new oem boot standby, and i normally buy oem cv boot from stealership and have my mechanic friend rebuild for me.
i do recommend new axle seal when replacing axle to prevent oil leak, those are only $7 to $10 each from stealership.
