Tie rod lock nuts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 03:23 PM   #1 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
Tie rod lock nuts
Are they both right-handed (lefty loosey, righty tighty)?
thaharlequin is offline   Reply With Quote
Old 03-03-2011, 03:50 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah theyre not reverse.
Dont forget ot get new cotter pins if your re using your tie rods.
carsrus is offline   Reply With Quote
The Following User Says Thank You to carsrus For This Useful Post:
thaharlequin (03-03-2011)
Old 03-03-2011, 06:28 PM   #3 (permalink)
Thanks for the verification. I'm just tweaking the alignment, but yeah, been there, done that. I re-used one on my VW, "just to roll it out of the garage", and naturally I forgot about it completely, so a few weeks later my FR wheel starts flopping around on the highway.
Old 03-03-2011, 06:55 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
ahhh, it reminded me that I re-used both axle nut cotter pins and tie rod castle nut cotter pins, because I forgot to have new ones on me when doing the job
... need to replace those quickly ... better safe than sorry
Old 03-03-2011, 10:05 PM   #5 (permalink)
You dont need to unbolt the tie rod to adjust it. Take the big nut on the end (21mm I think) Loosen it first. Then you can take a smaller wrench (12mm maybe) and spin the inner tie rod either to adjust in or out.
Old 03-03-2011, 10:06 PM   #6 (permalink)
Definitely, although I've felt fairly safe re-using axle nuts by torquing the crap out of them. To be honest the tie-rod end the cotter pin popped off was spinning on itself so I couldn't torque it down to what it should have been at in the first place.
