camry rubbing on 16" ?!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2011, 04:27 AM   #1 (permalink)
View dooooss's Photo Gallery
I bought new wheels ,, 225 - 55 - R16 ,, and it's rubbing from the back with no one set in back seats !!!
what's the problem ??
my car ,, camry 1999
one month ago I had change the rear pump ,, Is it the springs???
please help!!
dooooss is offline   Reply With Quote
Old 03-04-2011, 07:28 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
please help!!
More information about your ride, and rims your running would be helpful. Could be wrong offset on your rims
I run 215/55/17 on 09 SE rims on my 96 Camry without rubbing issues, and it's lowered on H&R's...
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 03-04-2011, 08:38 AM   #3 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
3rd Generation
Id assume its the offset of the rims b/c thats what tire Im running and I have no problems lowered on Eibachs. Sounds like you need a fender roll.
Got any pics?
4Cyl'erThriller is offline   Reply With Quote
Old 03-04-2011, 08:50 AM   #4 (permalink)
Bdub215's Avatar
Gameroom cash: $316065
View Bdub215's Photo Gallery
Aren't 225's a bit to wide for the camry?
Sent from my iPhone using Autoguide
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 03-04-2011, 08:52 AM   #5 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
^Depends on the offset of the wheels themselves. I've personally only upsized 1cm, to 205.. I don't see a need for any larger unless the wheels call for it. The only way to fix it is as 4cyler said, to roll the fenders. If the rubbing is bad you might even need to pull it.
iovaykind is offline   Reply With Quote
Old 03-04-2011, 09:51 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
IIRC after purchase I had Fuzion ZRi 225/55/R16 (or something close, need to double check) on rear rims (OEM) on my '02 Solara V6 after purchase. there shouldn't be any rubbing issues on camry either?? it's the same suspension.
pic of such tires mounted on rear OEM 16'' rims on car, no issues (rim is damaged though hehe)
However 225/55/16 is too wide for OEM rims in front, tires will be rubbing the strut towers.
Normally 16'' OEM tire size is 205/60/16.
Old 03-04-2011, 01:12 PM   #7 (permalink)
93 Camry LE 5S-FE
Actually I think my tires may be 205s But there still shouldnt be any rubbing problems unless the offset is too much for the car.
Old 03-04-2011, 02:27 PM   #8 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
My old AR wheels in your sig? Those are 235's.
To the OP... we need a lot more info here! Wheels? Offset?
'07 Honda Ruckus Big Bore
Old 03-04-2011, 03:04 PM   #9 (permalink)
93 Camry LE 5S-FE
No, Ive got a set of ICW 16s on for the winter (better tires for winter weather)
Im putting 225s on those AR rims and painting them bronze plus fixing the dents. =)
Yeah the 235s rubbed Ive never had any problems with 225s
edit: not the rims in the sig the last ones on pg 10 "My Ride" page
Old 03-08-2011, 12:26 PM   #10 (permalink)
Hi
I changed the springs and it's become so good ,, little bit higher but not rubbing ...
Thanks guys..
