Which tie rod ends to buy? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2011, 05:31 PM   #1 (permalink)
View 99offroadrngr's Photo Gallery
4th Generation Which tie rod ends to buy?
My 2001 needs new outer tie rods because the boots are leaking grease. Which brand should i get? I was checking out rock auto and there are a lot of brands but I don't see a toyota brand one listed. Should i go to the dealership and buy one or what? I've always run moog in my truck but I don't know what these cars prefer.
thanks
01 Camry LE
99offroadrngr is offline   Reply With Quote
Old 03-04-2011, 06:10 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I dunno .. I've put cheapos on my camry before and they lasted just as long as the OEM. I like the aftermarket ones anyways because they have a grease fitting so you can service them.
Old 03-04-2011, 06:15 PM   #3 (permalink)
alright thanks. I'll probably go with Moog.
01 Camry LE
Old 03-04-2011, 07:17 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I would get Moog only.
check your part number here:
http://www.moog-suspension-parts.com...s.asp?cat=1813
then look for it either in local Advance Auto parts (use $20 off $50 EM2 or $25 off $60 BIG25 or 20% off P20 coupons for online order and pickup locally) or order from rockauto.com even cheaper
Old 03-05-2011, 03:56 AM   #5 (permalink)
View Kingdom934's Photo Gallery
A lot of people say go with Moog usually. They are normally the better of the bunch, although do cost the most of the bunch.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 03-05-2011, 07:48 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235245
View speedy25's Photo Gallery
I'll confirm this with and installation of an "el cheapo" from one of the large discount chains that was worn out in 6 months!! Surprisingly I found a GOOD set of moogs on a car in the junkyard and they are still fine after 2 years.
Spend the extra bucks on the moog or take the gamble.
-SP
