98 camry 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2011, 11:27 AM   #1 (permalink)
View Charlie Smith's Photo Gallery
4th Generation 98 camry 5sfe
1998 camry 5SFE 80K miles, occationaly hesitates and sputters on accelaration. I ran a OBII live check and discovered that the ST FTRM was about -20% during an episode of sputtering. It occurs often when there is a slight load on the the vehicle ie. a hill. It will return to normal if I open the throttle, but sometimes it will backfire which I do not want to happen for obvious reasons. I visually checked the vacuum lines on the manifold and found no glaring problems. I do not have a fuel pressure gauge or a hand vacuum tool so I did not get that test done. My research points to a possible faulty fuel pressure regulator. Is it worth purchasing a new fuel pressure regulator? They run from 50 to 120 dollars. Wonder why the wide range of price? Do they fail often? Any Suggestions??
Thanks
Charlie Smith is offline   Reply With Quote
Old 03-05-2011, 12:34 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
dont really hear of failing fpr's, also look at sticking injectors
^ and leaving it that way!
Old 03-05-2011, 12:53 PM   #3 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
Thanks
I have the same problem, but I intend to put a bottle of Lucas fuel tune-up in a bottle:
http://www.lucasoil.com/products/dis...catid=2&iid=26
..and not take the big route and take it in somewhere to have them fix it just yet.
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 03-05-2011, 01:10 PM   #4 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
How old is the fuel filter?
deadrx7conv is offline   Reply With Quote
Old 03-05-2011, 01:12 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Thanks
negative fuel adjustment looks like engine is not getting enough air for proper mixture. have you checked/replaced the air filter recently?
is this car a California emission specs? if so then until '99 (inclusive) there is also an Air Assist tube going from bottom of IAC valve (below Throttle Body) and plugged into the engine head between fuel injector 2 & 3. make sure there is no cracks/restrictions in that tube.
IAC valve itself might be a problem too (dirty/sticky), restricting the air flow at slightly open throttle plate, or throttle plate itself might be sticky on edges.
FPR problem is very rare, same about fuel pump. but do check the fuel pressure at idle if you have time and the gauge. Fuel Pressue Norm is 44-50psi at ACC ignition (I think same should be at IGN ON when fuel pump works), should hold value for 5 mins (min 21psi) and show same value at idle.
I actually have the opposite problem, my fuel trims tend to go into strong positives at idle, looking like engine is getting some unmetered air from somewhere, but it fluctuates, sometimes looks perfect (+4% LTFT at idle) and some other time is bad (up to +14% LTFT at idle). almost impossible to find the root cause.
