'95 Camry Starting Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2011, 11:57 AM   #1 (permalink)
View blandusername's Photo Gallery
USA '95 Camry Starting Problems
I'm having trouble starting my '95 Toyota Camry. When I turn the key to accessories, the radio, wipers, horn, etc work fine. But when I try and start the engine, the car makes a clicking noise and won't start.
I got my battery recharged, and tried it again, but it did the same thing. The terminals and cables look fine IMO.
Could someone please advise on what could be wrong? What should I do next? What is the clicking sound I'm hearing?
Thanks!
blandusername is offline   Reply With Quote
Old 03-05-2011, 12:35 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
your starter solenoid closing, bad starter
^ and leaving it that way!
The Following User Says Thank You to chronoti For This Useful Post:
blandusername (03-05-2011)
Old 03-05-2011, 12:35 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
It's the click of doom, run fast and far!
Really it just sounds like the starter has failed, specifically the contacts. The solenoid is engaging but power is not reaching the motor itself.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
Old 03-05-2011, 12:42 PM   #4 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Thats used to happen to me too, I just took out the terminals to the battery, sanded them down and painted the non contact part.
This is probably the contacts though, but make sure all connections are tight and clean first.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
Old 03-05-2011, 02:23 PM   #5 (permalink)
USA
Thanks for the info... I really appreciate it. I cleaned my battery contacts and terminals, so I don't think I have a problem there.
So do I replace my starter now? I'm guessing I should buy the Toyota part and not the Autozone brand (Duralast). Please let me know...
Thanks again...
Old 03-05-2011, 02:33 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Did you also check the ground to the chassis? That could be corroded and cause the same sort of issues.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
blandusername (03-19-2011)
Old 03-05-2011, 02:38 PM   #7 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Did you remove and clean the connections at the starter? Wouldn't hurt to check the starter relay as well. You can remove the starter and get it bench tested at Autozone.
Buy new, not rebuilt. Duralast brand has some good stuff. Can't go wrong with Toyo but how long you plan on keeping this car and what is warranty of Duralast and Toyo as well as price difference?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
The Following User Says Thank You to Stillrunning For This Useful Post:
Old 03-05-2011, 07:40 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check the battery voltage as well. if it is below 11V than your starter is not going to crank the engine, instead you will be hearing that dreaded clicking/ticking sound repeatedly.
last time I heard it on my wife's car it was weak battery that got drained while she waited in car with shut off engine and lights on (just 15 minutes was enough to immobilize the car).
on crank attempt the battery voltage was plummeting down to 2V.
The Following User Says Thank You to fenixus For This Useful Post:
