When you say the shift is moving do you mean the gearshift lever? If so, then make sure the cable is moving the lever at the front of the trans. If that is moving, then there's a problem with the transmission. If it's not moving, then you'll need to find out if the cable or the shifter is broken. Also be sure the transmission fluid level is not low and is up to where it's suppose to be on the dipstick. Are you comfortable with and have some experience working on cars? Because if you don't and are not sure of where to look or what you're looking at, probably need to have a trusted shop look at it. Good luck and keep us informed!
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes  .
