I need counseling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2011, 05:08 PM   #1 (permalink)
View masonm's Photo Gallery
I need counseling
Just bought a new Camry and was a bit impulsive. I paid $2995 for it. It is seen here in the video I may post if you guys tell me to sell it:
I thought I was smart and bought it quick.
I then took it to my mechanic, and paid him a fee to assess the fixes needed in the next six months--I told him I would fix things myself. He said he would not put any money into it ( mind you he is a Ford man). He said the CV boots are torn (we all know what that eventually means), the radiator was leaking (easy and cheap fix), the Idle Valve was bad (poor cold starts), the struts needed to be replaced ( I don't really care), that there were a few small oil leaks ($350 repair), and that the timing belt needed to be changed ( I cannot do that one myself).
I was questioning his "opinion" and then I went to the first highly rated Google search result for a mechanic. Paid him a fee--also telling him I would fix things myself-- and he came back with the same results, plus he said that the transmission fluid needs flushed and that the Head Gasket was leaking (I can't fix that plus it ain't cheap).
My questions are these:
1) How can you tell if a head gasket is really leaking. I thought it was by checking for foamy oil...I also have no colored smoke out of my pipe. I just don't believe the "Google Search" guy (maybe because I don't want to face reality), being as my mechanic should have found it and it happens to be a $1600 all labor job that I cannot verify.
2) Should I keep the car or just sell it again? Craigslist average pricing in my area tells me I could get my money right back, and I don't want to hang onto a car just because I am stubborn.
So here I am. I thought I bought a gem, as I looked it over the best I could, but I now need advice. Please send me a response.
FYI: The guy who sold it to me was absolutely CLUELESS about cars, so I do not fault him at all. Also, there is a little bit of brake pedal travel, but they still feel solid.
masonm is offline   Reply With Quote
Old 03-05-2011, 05:26 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
The body looks kinda rough in places, but the engine sounds fine. Did you do a Carfax or other vehicle history before you bought the car?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 03-05-2011, 05:30 PM   #3 (permalink)
Yep, two owners: The mom for the first 118k miiles and her 35 year old son for the next 8k miles...who sold it to me.
Old 03-05-2011, 06:33 PM   #4 (permalink)
View DarkSideMoon's Photo Gallery
Originally Posted by masonm View Post
Just bought a new Camry and was a bit impulsive. I paid $2995 for it. It is seen here in the video I may post if you guys tell me to sell it: http://www.youtube.com/watch?v=sgXbVAq8lh0
Was there a maintenance history included with the car? My timing belt/water pump change was about 600 bucks, but they are both good for at least 80k miles. As far as the head gasket look for unexplained coolant loss, white smoke out of the tailpipe, foamy oil, and excessive bubbles in the cooling system. If none of those are present everything I've read would say your headgasket is fine. I have this same body style but the 3vz-fe engine and I love the thing, plus you'll get even better mileage than me, and I'd wager that car has alot of life left in it.
DarkSideMoon is offline   Reply With Quote
Old 03-05-2011, 07:02 PM   #5 (permalink)
View vickpick's Photo Gallery
nice buy.. not a bad car at all.
vickpick is offline   Reply With Quote
Old 03-05-2011, 07:18 PM   #6 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
In general its gonna be expensive to buy a car like that if you cant to most of the work DIY.
Struts can be done DIY easily with Quick Struts. The rad is easy. The timing belt is where the oil leak is probably coming from. Its not that hard to do and there is a GREAT write up on this site. Valve cover gasket can be done at the same time. Trans fluid change takes 15min as there is a drain plug and pan doesnt have to be removed.
RockAuto is a great place to order parts from. Quality stuff and I easily save 20-30% over going somewhere local.
If you put 500$ worth of parts into that car it'll be bullet proof. If you go to a mechanic youll spend easil 2k changing all that stuff.
carsrus is offline   Reply With Quote
Old 03-05-2011, 08:10 PM   #7 (permalink)
View rhymz's Photo Gallery
if u put ur mind to fixing the stuff urself, which isnt that hard, i vote keep it...the things u mentioned are mostly parts that u should be changing anyways, like timing belt and cv boots, ISCV can be cleaned/serviced by urself, etc
i have a gen 3 in far WORST condition...i wouldnt even post a pic with it how bad it is, but once u put a little money into it, its a car ur just gonna love...
rhymz is offline   Reply With Quote
Old 03-05-2011, 08:37 PM   #8 (permalink)
heartdisease's Avatar
Gameroom cash: $106070
View heartdisease's Photo Gallery
I am not sure about the rest but my experience with head gaskets is they don't always give the symptoms you describe. My pickup was dripping to the outside, no foam no noticeable loss for a long time. Then it got a lot worse quick. The only clue was a little smoke as the leak progressed and dripped on the exahust. If you aren't up to fixing a head gasket on your own and don't want to pay for someone else to do it than I would reevaluate things. The rest is minor compared to that one. Now that you have an Idea that it has these head gasket issues could you really unload it with a clear concise? I would drive it awhile and see what happens. do the easy stuff and if it really has these problems they will progess. don't screw somebody else
heartdisease is offline   Reply With Quote
Old 03-05-2011, 08:42 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
what was the reasoning behind HG leaking? that's just an unverified opinion. everybody can say about most of old cars (because they are old and have rough idle) that proves nothing until someone does coolant pressure test, engine cylinders compression test or leak down test, especially that there is no white smoke out of exhaust, no milky residue under oil filler cap and engine oil looks normal.
thing you mentioned are NORMAL maintenance stuff, don't fret it, it's a nice car.
timing belt needs to be done every 90k miles together with water pump, idlers and drive belts. parts are like $200 tops, labor you could do yourself if you have time and place to do that.
it's a good habit to flush ALL fluids on every car you purchase, you never know what prev owner(s) did ... or most likely did NOT do.
that includes engine oil and filter, coolant, power steering fluid (ATF), trans fluid (ATF) and brake fluid, tune up items like new spark plugs, air filter, fuel filter, sometimes new spark plug wireset, etc.
struts go bad over time, yours are probably factory OEM ... the factor OEM front ones wouldn't survive 40k miles in my area haha.
CV boots are a pain, but don't worry, such stuff happens.
get a metric socket tool set, some cheap torque wrenches from Harbor Freight Tools, metric combo key set and start thinking about taking care of that car.
as above, cheapest parts from rockauto.com
if you need something crucial, go with OEM from online dealers (30% off MSRP over the counter locally).
Autozone will borrow you (refundable deposit required) most of one time use tools you will ever need.
think about doing a minor tuneup on car as well if there is no record history. there is a bunch of small things that should be in order and some of them work only right from dealer (radiator cap, fuel cap, thermostat, PCV valve and grommet, etc.)
get a Haynes manual for your gen3 camry and make yourself a bullet proof car
If you only knew what I had to replace on my cars (still not done haha)
Old 03-05-2011, 09:49 PM   #10 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
OP... PM coming your way.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
projektvertx (03-06-2011)
Old 03-06-2011, 11:10 AM   #11 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Thanks Ken
To me, this car seems very fixable. Head gasket? That should be easily verifiable. Do a compression test. CV boots aren't that bad either. I would get a new halfshaft, truth is, it will cost you the same amount to rebuild as to replace with new. Either way, the shaft has to come off. Everything you mentionned is normal of an old car. I would keep it
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 03-06-2011, 11:46 AM   #12 (permalink)
View 69GTSport's Photo Gallery
I picked up my '95 for $2300 and it needed alot of work to make it so that I would feel comfortable driving it anywhere even though it had only 109K miles on it.
The low pedal travel is probably just the rear brakes needing cleaning and then adjusting. Mine were the same way and I also had the drums turned to get rid of a pulsation.
Here's an idea of what I have put into my '95: wiper blades, some light bulbs, serpentine belts, front brake pads/rotors, valve cover gasket, spark plugs/wires/distributor cap/rotor, the timing belt/tensioner spring/waterpump/t-stat/timing belt bearing pulleys/crank seal/cam seal/oil pump and its seal, radiator/ps steering/trans fluids, a rack and pinion rubber bellow, trans nuetral/safety switch, rear sway bar bushings, front engine mount, both cv axles, new tires, alignment, new battery, charged the a/c, and upgraded the upper engine dogbone mount to the newer style.
I also did some paint work (hood and rear quarter rust).
I did it ALL myself (except tires and alignment) which, as you can imagine, took some time to do. I just fixed the most important stuff first and then moved on from there. I probably have 40-50 hours of my own labor into it.
One other thing I had a snag with and needed professional help is since I live in the salt belt, I was unable to get the passenger cv axle out of the carrier bearing bracket, but it was still doable by removing the axle along w/ the bracket that holds the bearing, but it wasn't easy since that bracket has dowel pins you have to fight with. Then I had a local tire shop remove the cv axle/bearing assembly from the bracket with their torch.
Now that all that is done I'm not afraid to take it anywhere.
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes .
69GTSport is offline   Reply With Quote
Old 03-06-2011, 01:05 PM   #13 (permalink)
Gameroom cash: $814501
View zythr's Photo Gallery
One other thing I had a snag with and needed professional help is since I live in the salt belt, I was unable to get the passenger cv axle out of the carrier bearing, but it was still doable by removing it along w/ the bracket that holds the bearing, but it wasn't easy since that bracket has dowel pins you have to fight with. Then I had a local tire shop remove the cv axle and bearing assembly from the bracket with their torch.
In short, you rebuilt the car?
zythr is offline   Reply With Quote
Old 03-06-2011, 01:10 PM   #14 (permalink)
TN's Mad Chemist
I wonder what you would say if you saw a list of things I've done
1997 Acura RL-Gone
Old 03-06-2011, 01:34 PM   #15 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
In late 05, I paid 3400 for the 1MZ SE version with 140,000miles on it. I knew going in to it it needed Rack and both axles due to boot loss (only one was bad tho).
I'd make sure it passes DEQ, no engine light on, change the tranny fluid and find out why someone thought it needed a HG. Does it leak to the outside and run down the block somewhere?
As said, after that its all normal wear and tear you'll find on cars of this age.
Do Safety related items and items like the HG (if needed) so you don't kill it by over heating etc, and then pick off the other items as your budget permits.
Best of luck!
73sport is offline   Reply With Quote
