Camry intake vacuum reading (video included) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2011, 04:01 PM   #1 (permalink)
View dave255's Photo Gallery
1995 Camry; 5sfe; 247,000 miles
Over the past 5 years or so I have noticed a very gradual decrease in my car's fuel efficiency. I am currently getting about 24-25mpg on average, whereas about 5 years ago I was getting about 29-30.
This afternoon I hooked up a vacuum gauge to the intake manifold for the first time in the life of my vehicle to see if the results would give me any clues.
I have never done this test before, but from what I can tell, my car's performance seems spot on. Though since this is the 1st time I have done this, I thought I'd post a video of the gauge as I ran the test to get feedback from more experienced members of the forum. In the video, you will see the vacuum gauge with my car at a steady idle. I also threw in a few short bursts to 2500rpm and then back down.
Any thoughts, comments, concerns would be greatly appreciated. Thanks in advance!
dave255 is offline   Reply With Quote
Old 03-07-2011, 08:26 PM   #2 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
My first guess for the dropping fuel economy is your 02 sensor. I had 265K on mine when I replaced both of them and gained close to 3MPG highway. Secondly a good thorough decarbonization of the throttle body and intake will allow more air to get to the cylinders. Finally, the EGR could be clogged or resticted which could affect MPG as well...
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 03-07-2011, 08:30 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
also all this mixing fuel with ethanol will loose you a few points, try to find a gas station that sells unblended fuel
^ and leaving it that way!
Old 03-07-2011, 09:15 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There is some fluctuation of the needle. When was the car tuned up last? Valve clearances checked?
Old 03-07-2011, 10:26 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I believe that slight fluctuation on the needle might indicate a leaky gasket (e.g. valve cover or distributor plug), that would account for a tiny slight vacuum leak I think?
Old 03-08-2011, 06:46 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by dave255 View Post
Over the past 5 years or so I have noticed a very gradual decrease in my car's fuel efficiency. This afternoon I hooked up a vacuum gauge to the intake manifold for the first time in the life of my vehicle
Did you do a compression test 5 years ago? Doing tests early to establish base numbers for comparison is a good idea. The gauge readings are within spec - 17 - 21 at idle and 2 - 25 on accel/decel. Mileage drop may not be just engine wear so I'd look at what's been suggested, O2 sensor, ethanol, etc. which are things you can actually fix.
Oh, and look for poorer fuel mileage as our illustrious government has decreed that there can be up 15% ethanol in gas.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-08-2011, 04:15 PM   #7 (permalink)
Gameroom cash: $303755
In addition to what has already been posted, make sure you are not comparing Winter fuel mileage to Summer fuel mileage. Winter fuel mileage will decrease as the engine is taking a lot longer to reach operating temperature. During this warm-up period you are running a richer fuel mixture.
In addition I think you are geting excellent fuel mileage. I have a 94 Camry 4 cylinder 5SFE engine that I have owned since new. The car was rated at 21 city and 28 highway. Your 95 should be the same. I get around 20 MPG city in extended around town driving and around 29 on the highway. In Winter the mileage for city driving drops to around 18-19.
Mike
Old 03-08-2011, 08:03 PM   #8 (permalink)
Possibly. Your leak made the needle tick like clockwork however.
Old 03-08-2011, 08:17 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, it was slightly different. I will check again before and after resealing with RTV the distributor plug (leaking now), hopefully it smooths out a bit.
