auto to manual reverse light question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2011, 08:50 PM   #1 (permalink)
View jdm_eh9killer's Photo Gallery
hey guys, i'm new to the site but not new to the camry. i've had the auto to manual successfully swapped in my 92' 5sfe for a little over a year now but have never figured out how to make the reverse lights work. also, i'm still running the auto ecu and wiring harness. basically, i need to figure out how to wire from the auto reverse sensor pigtail to the manual reverse sensor. future plans involve 3sgte head and maybe turbo! woot woot
jdm_eh9killer is offline   Reply With Quote
Old 03-08-2011, 12:39 AM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
...why not just get a 5 speed ECU and wiring harness...?
Chris Crash is online now   Reply With Quote
Old 03-08-2011, 03:48 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
or he could cut the connector for the gear selector and take the thick black line from it and the reverse line and connect it to the reverse switch so when the car is in reverse it closes the connection that the gear selector normally closes for reverse
^ and leaving it that way!
Old 03-08-2011, 08:05 AM   #4 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
or you could look at the wiring diagram =)
the switch is on the transmission as far as I can tell. seconding the proper manual ecu as well, theres one on ebay now for $100
rusty9 is offline   Reply With Quote
Old 03-08-2011, 12:28 PM   #5 (permalink)
Yup. The switch is on the top of the tranny, sticking straight up directly to the right of the engine block. It's near the flat part where there's a few grounding spots and the clutch line goes near it as well.
You'll need the connector to it and be able to splice it into the auto harness. I hate wiring harnesses haha.
Old 03-12-2011, 02:03 PM   #6 (permalink)
hey chronoti, i finally got a chance the work on the camry again but i still havent found the thick black wire at the gear shifter.
Old 11-16-2011, 10:18 AM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Okay this is a pretty old thread, but I'll tell you how to do this.. As I have just finished swapping my 5speed in my 95 a few weeks ago.
Pretty simple. Get a test light, put the NSS in Reverse and probe the wiring until you find the single wire that goes to reverse. Confirm it by turning the NSS in park while still probing the wiring.. the light will shut off. Cut this wire at the plug and Solder or using a connector add a 4-6" Piece of wire.
Next, find your constant power (should be a slightly thicker wire). Note: Dont run the power from the battery, because if it ever shorts its going to just melt and catch on fire without a fuse. Once you find the constant power on the NSS, splice into it (DONT CUT IT OFF). Connect a 4-6" length of wire to the Power wire that is still attached to the NSS.
Now you can connect it to the transmission 1 of 2 ways.
1. Get a 5-speed OEM Reverse Pigtail from the junk yard. Snip it, cut it, whatever you have to do and splice it into the two wires you now have.
2. Get two small Pin Connectors, and crimp them onto the wiring you spliced into on the NSS. Make sure to put RTV silicone into the top of the plug if you do it this way, so its protected from the elements.
I did Option 2 because I didnt want to cut my manual harness I have.
If you want to swap harnesses, keep in mind you have to replace the entire Under-dash harness.
