DIY - 2000 Camry LE, adjustable Torque Strut (Dog Bone) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2011, 09:33 PM   #1 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
This DIY is specifically for a 2000 IMZ-FE, 6-cyl Camry but will probably work for most any model year that has this type of Torque Strut, more commonly known as the "Dog Bone".
I was doing some minor maintenance on my car, and just happened to glance over at the Torque Strut and noticed that it had little cracks in it. I took it out for a closer look, and sure enough the rubber was split as you can see in the close up below. NBD, since when I replaced my front motor mount a while ago I ordered a set of all the mounts, but didn't change the Torque Strut since it didn't need it. But now it did, and I had one, so I swapped it out.
The next day I'm driving around and I notice that when I took off from a stop light the car jerked a bit as if the transmission was slipping. Sure enough at every stop light, when I accelerated, there was a very brief "thump" as if the transmission slipped and then caught. There were no other problems, but I wasn't looking forward to a transmission re-build.
Then I remembered I swapped out the dog bone. I wonder if that would cause the problem. So when I got home I put back in the original one, and drove around. Much to my surprise the thumping/slipping went away. So the "new" dog bone was fubar, and I was just planning on throwing it away, since when I had them both out, I noticed that the part number on the one that was cracked was 12363-20020 which means it was OEM, and the eBay one was, well Chinese crap.
But then I got to wondering what the difference was. So I took the OEM one out and compared it to the eBay one side by side. Much to my surprise the eBay one was a bit shorter, but the OEM one had a much larger hole in it, so the mount could slop around on the OEM one, but not the eBay one. It would have been so much easier if they just made it adjustable, so you could fit it to suit the condition of the rest of the mounts.
Why wait for Toyota to do it, I'll do it, and make the first Camry Adjustable Dog Bone Torque Strut Mount.
As luck would have it, when I measured the thickness of the rod, it measured .475" and that would make it easy to thread for 1/2" 13 threads and I had the necessary hardware laying around so it wouldn't cost me anything to make this. Just a little time.
Here's a shot of the two struts along with a close up of the cracked OEM rubber part. You can see the difference in the size of the holes, and the length of each strut.
Here's where I cut out 1/2" of the rod and threaded both ends of the cut piece. Notice the one end's threads are less than the other. The reason for this is I'll thread the nut coupler on to the short end, bottom it out, and then drill and tap a hole for a set screw. Drilling and tapping for a set screw probably isn't really necessary, but it will ensure that the one end never rotates. The other end can be screwed in or out to the correct length and the locked in place with the nut. I could have used a lock nut on both ends, but I opted to fasten one end permanently and not have to use a lock nut. If you don't want to go to all this trouble, just use two lock nuts.
Run the nut coupler until it binds up on the threaded shaft, and then drill and tap for a set screw.
This pic shows it all put together, and set to the approximate length.
And finally installed in the car. Kinda looks like it belongs there, eh. I'll be curious to see if anybody will ever spot the modifications.
I took the car out for a drive, and there was a slight clunk when I took off from a stop. I adjusted it one turn longer, and everything's working just like it should. One thing I did notice is that the eBay strut had much softer rubber than the OEM one did. I don't know if it's because the OEM one was in there for so long, or if it was made that way. Next time I'm out at Pick-N-Pull I'll see if I can get another OEM one for comparison and modification.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 03-07-2011, 09:55 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Very cool, I had a clunking problem coming from the torque strut, turns out the mounting bolts and mount stay bolts were not tight.
Oh btw, I'm doing cam seals again.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 03-07-2011, 11:24 PM   #3 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
very nice diy and great pictures. this will be very helpful for all of us. thanks for sharing.
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline   Reply With Quote
Old 03-08-2011, 05:22 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
very similar with my custom torque strut, never thought about adjusting it for a difference in drivablity. mine is 2 hime joints and some all rod with a poly bushing to take out some vibration
^ and leaving it that way!
Old 03-08-2011, 12:27 PM   #5 (permalink)
I remember that thread well. I just wish I could get some of the polyurethane goop in smaller quantities. I really don't need, or want to pay for a gallon of the stuff, maybe a pint, or a quart to do some experimenting with.
Any ideas where I can get a small quantity?
Old 03-08-2011, 12:46 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nice custom dog bone
Old 03-08-2011, 01:21 PM   #7 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
I want the goop too !
And what is a hime joint ?
j
JimBowNut is offline   Reply With Quote
Old 03-08-2011, 01:26 PM   #8 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Chris Crash is online now   Reply With Quote
Old 03-08-2011, 01:26 PM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
kudos for taking the initiative, but im still wondering why it would be necessary for it to be adjustable.
Old 03-08-2011, 06:02 PM   #10 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Thanks for the innovative DIY Al. But how will it solve the cracked rubber problem? I guess 3M Window Weld has been a very popular alternative. Its 12 bucks but I dunno about the durability. Thats the only part that worries me. Under sustained driving the polyurethane should not come apart. I have read stories of DIY PU mounts falling apart in 3 years or so.
Having said that I dont think any supplier makes a complete PU mount for Gen3/4 camries. Energy Suspension may make bushing/inserts but a torque strut mount? Not sure
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 03-08-2011, 08:04 PM   #11 (permalink)
I noticed that both OEM and el-cheapo deluxe one both had some slop before they were bolted up. So I just figured it would be a good idea to come up with something to take out some of the looseness. The longer the mounts are in there the looser they get.
Getting a new OEM one would probably solve all the problems, but what's the fun in that?
Old 03-08-2011, 08:21 PM   #12 (permalink)
I don't think the window Weld would last very long. One other TN member (lemegacool) already made up some using some stuff from McMaster Carr, called Forsh Polymer. Another source is Alumilite and they have a product called Flex 60, Flex 70 and Flex 80 where the numbers are the hardness durometer readings. SmoothOn has a couple products PMC-870 (70a) and PMC 780 (80a). They also have coloring agents that you can add to the mix and I was thinking about the boring black, but then I noticed they had Orange and Violet. Now that would be something eh, a Violet urethane Dog Bone.
Either way it's gonna cost $30.00 for the minimum quantity plus shipping and while others have used the harder 80a, I think it's too stiff, and would like to try some of the softer ones, maybe 60a or 70a. So that's about $100.00 right there in sample goop without shipping so maybe I'll just put this on the back burner for now and be happy with the only adjustable Dog Bone on the planet.
Or maybe just go buy a stock OEM one and be done with it. Nah, that would be too easy.
