Boiling noise from coolant reservoir - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2011, 01:46 PM   #1 (permalink)
View azcat90's Photo Gallery
3rd Generation Boiling noise from coolant reservoir
On my 93 Camry XLE V6 (3VZ-FE) every time I turn off the engine after driving a while I hear a boiling noise coming from the coolant reservoir even though the temperature guage is normal the whole time I'm driving. I've only had it since December so I don't know what it will do once the Pennsylvania winter is over... I have not heard the radiator fan come on since I bought it - that might be because its cold...
Any ideas?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
azcat90 is offline   Reply With Quote
Old 03-08-2011, 02:11 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
something is causing the coolant to boil. there are several things that will cause this:
thermostat stuck
cooling fan not working
radiator caps not holding pressure
blown head gasket letting exhaust gas into the coolant
first and easiest thing to replace is the caps. for some reason this system is very sensitive to worn out radiator caps. i recommend getting both from the dealer, as aftermarket ones arent the best for this application in my experience.
you can check the cooling fan and find a lot of info about in this post Hydraulic Fan Diagnostic Checklist (3vz-fe) you can do a quick test by jumping terminals E1 and OP1 in the diagnostic plug to see if the fan spins up to full speed.
rusty9 is offline   Reply With Quote
The Following User Says Thank You to rusty9 For This Useful Post:
azcat90 (03-08-2011)
Old 03-08-2011, 02:19 PM   #3 (permalink)
Thanks
Thanks - I'll check it out - I hope its not the gasket(s)...
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 03-08-2011, 02:23 PM   #4 (permalink)
When you say caps you mean the fill cap at the top of the engine and the one on top of the radiator?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 03-08-2011, 02:27 PM   #5 (permalink)
rusty9's Avatar
yes. i had the same problem last year. mine was a faulty head gasket, but other people here have had it be just the caps. or even the solenoid connector on the PS pump was disconnected.
Old 03-08-2011, 03:08 PM   #6 (permalink)
Yeah -I just read the repair manual instrcutions for replacing head gaskets. Ouch. That is a ton of labor. There is no way I'm going to start messing with valves and cam shafts. This is one advantage of the 2.2 L engine - my V6 doubles the work.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 03-08-2011, 08:00 PM   #7 (permalink)
View DarkSideMoon's Photo Gallery
I've had issues with the cooling system, turned out to be a combination of the water pump going bad, the fan not working properly, and having literally around a liter of sludge in the radiator. You said the fan doesn't come on at all. Do you mean literally not at all? If so there is definitely something wrong there. Easiest way is to jump the terminals and you should see a significant increase in speed. If it doesn't you have an issue somewhere in the fan system.
DarkSideMoon is offline   Reply With Quote
Old 03-08-2011, 08:41 PM   #8 (permalink)
View rhymz's Photo Gallery
had this problem and it turned out to be the cap, aftermarket ones are complete crap IMO, if the fan isnt coming on it could also be the fan relay in the under hood fuse box (had this problem as well)
rhymz is offline   Reply With Quote
Old 03-10-2011, 11:39 AM   #9 (permalink)
I haven't sent it to the shop yet but the outside of the engine is wet around the front head gasket on the drivers side... I'm wondering if its better to buy a used engine and do a swap. Isn't a blown head gasket an indicator of more damage inside? I know at one point the radiator exploded and was replaced.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 03-10-2011, 11:42 AM   #10 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
This happened to me once and turned out to be a wrong mixture of water and coolant. Too much water not enough coolant, so the water started to boil.
Chris Crash is online now   Reply With Quote
Old 03-10-2011, 12:24 PM   #11 (permalink)
The temp guage is always in the good range but it is still winter here... and the engine block is wet. Does anyone have an opinion about Thermagasket? Will it work on a 3VZFE (cast iron block)?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 03-10-2011, 05:32 PM   #12 (permalink)
I'm kind of leery of putting any additives in to stop something like that. I tried putting bar's leak in once and all it ended up doing was gumming up my coolant system. A head gasket repair would probably be significantly cheaper than a new engine if you do it yourself.
Old 03-10-2011, 05:43 PM   #13 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
No Bar's Leak, tried that in my Voyager, and lets just say I don't have the car anymore.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 03-11-2011, 04:33 PM   #14 (permalink)
View csharp100's Photo Gallery
Not necessarily. A blown head gasket could be caused by a warped cylinder head. The cylinder head could have warped because of overheating. This does not mean you have problems with pistons, rings, etc. If your seeing dampness there, something is not right. Run a compression check and see what you get. A compression tester can give good info on the internal condition of the engine including rings, valves and gaskets. Is your CEL on? What codes have been pulled?
Oh! For god's sake, do not use any of the stop leak or any of that other crap. Suck it up and fix it right the first time. You'll be happy you did.
csharp100 is offline   Reply With Quote
Old 03-11-2011, 06:57 PM   #15 (permalink)
truth...i have learnt from experience that those quick fix products just make u spend more in the end...
hey i tried this once with a similar problem, try to retorque ur head bolts...actually did that and my blown HG symptoms went away...strange i know
Tags
camry 1993, cooling system, radiator
