1994 Camry Power Antenna Mast Install? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2011, 07:22 PM   #1 (permalink)
View Hobo's Photo Gallery
I have a 1994 Camry LE Sedan, 4cylinder.
I ordered a new Power antenna mast.
The old one was long gone so when I install the new one I'm not sure which direction the teeth on the drive cable should face.
Anybody know?
Here's a link to the instructions I''m going to use the the mast arrives.
http://www.antennamastsrus.com/Instructions%20Mast.htm
Hobo is offline   Reply With Quote
Old 03-08-2011, 08:04 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
I highly recommend you remove the antenna from the car, and pull off the drum cover. Clean out the old grease, and repack with a lithium base. Then take the new mast and wind it around inside of the unit and put the cover on, it's not hard. Or can do what those instructions say to do, feed the new mast into the unit and have someone turn off the radio. Either way, dismantle the thing to clean it up, otherwise your new mast will not last very long.
Now to answer your question, you can't really put the teeth facing the wrong way because the teeth won't mesh, plus you will be bending the mast the opposite direction that it comes curled in.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
projektvertx (03-08-2011)
Old 03-08-2011, 08:37 PM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
What he said. I used this DIY. It's for an LS400, but the procedure is virtually identical.
http://www.lexls.com/tutorials/audio/powerantenna.html
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 03-09-2011, 01:47 AM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
There's also a DIY in the DIY sticky.
'07 Honda Ruckus Big Bore
Old 03-10-2011, 01:28 AM   #5 (permalink)
Thanks for the tips & suggestions.
Looking forward to having the power antenna back.
Old 03-10-2011, 09:41 AM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
It's been a while since I did mine, but I'm pretty sure the teeth on the mast's whip need to face the rear.
BMR is offline   Reply With Quote
Old 03-10-2011, 11:51 AM   #7 (permalink)
View White95Cam's Photo Gallery
I recently replaced mine and I had to take it apart to remove the broken part of the plastic cable that was inside the drum. The new OEM replace antenna has a longer cable (about 6 inches) than the original one. I called my parts guy and found out that it was correct and he told me twice to not cut off the extra length. The new length is suppose to help the antenna run more smoothly and not break. After I lubed and reassembled the drum I turned the teeth towards the rear of the car turned off the radio and the motor pulled the mast into the housing. It did not pull the mast all the way down but after I tightened the fender nut and cycled the antenna again it retracted completely. It is very quite and smooth compared to before.
W95c
White95Cam is offline   Reply With Quote
Old 03-10-2011, 01:16 PM   #8 (permalink)
The antenna just came in the mail.
Hope to install it later tonight or tomorrow.
Old 03-11-2011, 10:47 PM   #9 (permalink)
OK, I got the new antenna mast installed tonight. I took 71Corolla's advice and removed the drum cover and I'm glad I did. There was still a lot of the old plastic mast inside. I removed it cleaned up what I could and put in some white lithium grease.
I couldn't disassemble it enough to install the mast so reinstalled the motor assembly and installed the mast by turning the radio off. That was the tricky part. I didn't have anyone to help me so I ended up using a long piece of wood trim thru the back window to turn the radio off while I fed the mast into the antenna sleeve.
It's working great now. First time the car's had an antenna in about seven years. It was my ex-wife's car but I got her to trade me for my 99 Nissan Altima.
