93 SE factory stereo swap questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2011, 03:11 AM   #1 (permalink)
kmfdeviant530's Avatar
View kmfdeviant530's Photo Gallery
So I decided that I would like to swap out the stereo from the SE with one that I had from my 4runner. the plugs are a little different and I believe that is because the SE has the premium sound package, where can I get a wiring harness that will use the premium sound, or can I use a regular one
Also I noticed that there are 2 antenna plugs, A larger one and a Smaller one, googled it to see if I could find anything, closest I found was that the two could possibly be used to make a clearer signal, can I buy a antenna adaptor that will use both of them on an aftermarket stereo? because the one I have only has the larger antenna plug.
its a new stereo too, Dual, HD radio, BT with an USB and auxillary plug on the face.
09 Rolla S. The ex kept it along with the payment.
93 Camry SE. Custom Intake, PnP, ACIS mod, MAF tune, 2.5" Borla Axl bck exhst. 225/45zr17 Proxe 4's, 1.3" st lowering springs, fsb, fidanza flywheel, exedy clutch.
http://www.cardomain.com/id/KMFracing530
kmfdeviant530 is offline   Reply With Quote
Old 03-09-2011, 04:37 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
the12volt.com
crutchfield.com
'07 Honda Ruckus Big Bore
Old 03-09-2011, 10:03 PM   #3 (permalink)
Originally Posted by LynchburgCSI View Post
the12volt.com
crutchfield.com
thanks for the sites! the12volt is sweet, never heard of it. already did my search on crutchfield, I found my answer for the adaptor, I need a 15 pin w/ external factory amp. still have no clue what the two antenna plugs are for. I have to do some filing on the bottom of the plastic bin that was out of the runner to fit it in the camry.
Old 03-09-2011, 10:46 PM   #4 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I'm pretty sure they are the AM and FM plugs.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 03-09-2011, 10:57 PM   #5 (permalink)
Freakin Scooters
I LOVE the12volt. Best site ever. I think I may know what the deal is wih the antennas too. One for the power antenna mast extension, and the other for the antenna's AM/FM signal? You're talking about a lightblue and a solid black heavy gauge wire right?
Old 03-09-2011, 11:56 PM   #6 (permalink)
not sure about the light blue. but I know the larger heavy gauge is black, and the plug is the normal size for antennas, and right next to it is a similar looking plug, slightly smaller, and they both are joined together.
Old 03-10-2011, 12:01 AM   #7 (permalink)
unless its a special AM booster I do not believe that's what it is. out of the probably 25+ stereo installs ive done I have never seen this before, and AM/FM always works on the stereo with just the normal Antenna plug.
Old 03-10-2011, 12:02 AM   #8 (permalink)
ill get pics tomorrow.
