Bulb replacement light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2011, 10:48 AM   #1 (permalink)
Mario Mobile
DM616's Avatar
Gameroom cash: $221100
View DM616's Photo Gallery
I noticed it today while driving on the road.
Most of my bulbs have been replaced by LED SMDs. I recently just installed a trunk light. My ashtray bulb has been blown since I got the car, and the light was never on for it. I just checked:
-Headlights
-Signal Lamps
-Tail Lights, Brake Lights and Turn Signal Lights
-License Plate Bulbs
-Trunk Light
-Dome Light
-High Mount Stop Light
-Glove Box
I have not checked reverse lights or the center console. But I'm pretty sure those are fine.
Would a bulb that died on the cluster indicate this light as well? I don't think anything burned on the cluster though, I'll have to double check.
Is it possible replacing with LEDs causes this? Afterall, I just installed the trunk light (but I never noticed the bulb replacement either before).
The only other thing I can think of is maybe a ground wire broke or shorted out, but wouldn't lights fail to light because of this?
Thanks for the help
DM616 is offline   Reply With Quote
Old 03-09-2011, 11:15 AM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Not really, there's no indicator warning for a blown bulb in your center console. Replacing your bulbs with LEDs doesn't blow out your fuses or shorts out your ground wires.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 03-09-2011, 11:39 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
try unplugging the LED trunk light and see if problem gets solved.
that dash board indicator shows up only for rear brake lights failing to light up, it will account for intermittent problems too. Maybe the trunk LED is pulling more than stock power through wiring and cheats somehow the fancy burn-brake-light-detector-box circuit?
Old 03-09-2011, 11:54 AM   #4 (permalink)
Mario Mobile
DM616's Avatar
Alright it seems it is my left brake light, double checked it and yep, it's completely gone now lol.
I'm going to buy halogen bulbs to hold me over, but can you replace them with LED SMDs without modifying anything? Seems like you would need to do something.
