Overheating problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2011, 12:59 PM   #1 (permalink)
View mbrannon's Photo Gallery
Overheating problem
My 1995 Camry LE has been running hot and I'm always having to put coolant in it but I can't tell that there's a leak any where. Also - my fans don't seem to come on when the car is idling.
mbrannon is offline   Reply With Quote
Old 03-10-2011, 05:45 PM   #2 (permalink)
View DarkSideMoon's Photo Gallery
Do the fans come on at all? Which engine does your car have?
Is there any puddling underneath car? You might want to try UV dye for your coolant, let it run for a few days, and then use a black light to see if you can find any leaks- It could be falling on a hot part and evaporating. How full is your coolant reservoir when the car has been running awhile?
DarkSideMoon is offline   Reply With Quote
Old 03-10-2011, 07:53 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Do you get heat from the heater? What's the temperatures of the upper and lower radiator hoses? Have you tested the fan motors? Do both come on when you turn on the AC? Have you ever changed the thermostat? How often do you replace the coolant? etc etc
