Fixing valve cover leak-suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2011, 08:44 PM   #1 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
Alright, I've done lots of mechanical repairs on Toyota and other cars before, so I'm not a total newbie, but this is the first time I'm going to pull apart my perfectly running Gen3 V-6. I have to replace the rear valve cover seal, because it is flowing oil, and makes a bad smell every day, and my condo is ruled by a bunch of old far...s, that really take offence to this among their pristine BMW's and other 3 year old or newer cars.. I just purchased all the required gaskets (valve covers of course, and intake plenum). I have a Hanes manual and some handy pics the dealer was nice enough to print up for me of the parts in exploded view. Since I'm going in there, any tips on extra things to do along the way, or to look out for?
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 03-10-2011, 08:55 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The problem may be with the valve cover bolts not putting enough pressure on the cover. Either get new ones or add a couple of washers. The wavy stack looses compression force. Not the best design. I think there was a thread discussing this.
You have new spark plug tube seals and some RTV? PCV valve and grommet? How about checking valve clearances? Valve stem seals can wait until the next timing belt change.
Old 03-10-2011, 08:57 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
PCV Valve and Grommet, Rear plugs if needed. Clean the tb and iacv. Also the Intake plenum if you want to spend the time. Iacv coolant hoses if needed.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 03-10-2011, 08:58 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
How is the condition of the cam seals?
The job is not that hard, but of course you will have to at least partially drain the coolant. Make sure you cover the intake manifold so nothing falls into the engine. And while you're at it, replace the spark plugs unless they have been done recently. The half-moon plugs will also need to be sealed up, as well as the plastic cam plug on the drivers side of the engine.
Really the hardest part is getting the wiring harness out of the way enough to give clearance to remove bank1 cam cover (firewall side). Also, replacing the spark plug seals is a bit tricky.
If you need help, I can always come over and give you a hand.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 03-10-2011, 09:14 PM   #5 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
This thread has everything that you need to know about changing out the valve cover gaskets. The first couple of pages are on the top end maintenance but the valve cover stuff starts on Page 3.
Need Advice
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
The Following User Says Thank You to ajkalian For This Useful Post:
Silent Runner (03-10-2011)
Old 03-10-2011, 09:50 PM   #6 (permalink)
Domesticon Prime
Thanks guys! I appreciate the advice, and I'm going to add a couple of things to my shopping list before I dig in. I'm paying close attention, because the heads are going to come off this summer after a local shop ports and polishes a set of donor's for me. It's funny though, I've done turbo replacements, suspension stuff, ripped the entire interior out of the car, lots of sound and electronics,.. but this still makes me a little nervous.
Domesticon Prime
Old 03-10-2011, 10:38 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
PM sent
Old 03-13-2011, 12:55 AM   #8 (permalink)
Domesticon Prime
Alright, the job is done but jeeess, it whas actually a bit of a bugger. I cleaned the iavc, scrubbed down the throttle body, cleaned up the cold start injector and checked the condition of all the hoses related. This was done about 4 years ago, so it looked like they replaced alot of stuff already and it was in good shape. What was nasty was the little stuff that manuals don't tell you about re-assembly. Like don't tighten the throttle body down until you have re-connected all the braces, egrs, and bs bolts on the firewall side of the engine. They also don't really mention that it helps to be fairly physically strong, in order to pull,push and yank all the necessary stuff around. It would have been nice to have someone helping out with this job besides my very bord poodle. No wonder Toyota charges $600 or so for this job. So far, so good, no leaks, no check engine lights, just a sore back and knees. BTW. I could have had the cylinder head off my old Toyota Corolla, back on and running in much less than the 7 hrs or so it took me to do this job. Lots of respect to you guys who pull this car apart like its easy...
Domesticon Prime
