Instrument CLuster Background Bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2011, 01:10 AM   #1 (permalink)
View PaulPR's Photo Gallery
I just finished replacing the background bulbs on the instrument cluster on a US made '92 Camry LE. I figured once I got the gauge cluster out it would be a 1 minute job to plug in 4 bulbs. Not quite! While they are common 194 bulbs, the wires at the bottom of the bulbs wrap around the brass contacts of the socket.
For each bulb, I had to cut the end of the wire the dead ends into the glass base and straighten it out. Then the bare ends are threaded through the base. A U bend is made in the wire to pass back around the other side of the brass contacts.
I did a search on the site and didn't find much info on this, so figured I'd post this. Someone mentioned that the Japan made cars have a different socket that allows the bulb to just plug it.
PaulPR is offline   Reply With Quote
Old 03-11-2011, 04:15 AM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
You could of simply just bend it at the sides and just plug it in. That's what I did. Easy and stays snug.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 03-11-2011, 01:41 PM   #3 (permalink)
I thought about that, but it didn't seem to me that that was going to make a positive enough electrical connection to hold up long term. Seems like they must have intended the bulb and socket to replaced as a unit.
I sure don't want to take this apart again.
