Do i have an oil leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2011, 06:16 PM   #1 (permalink)
tylerho's Avatar
View tylerho's Photo Gallery
4th Generation Do i have an oil leak?
I have a 99 v6 camry, today i decided to change my oil but i don't know what liquid is leaking. So if someone could help me out, and one more thing i went over a speed bump that has scraped the bottom of my car for the pass two day due to my school construction. no matter how slow i go through it still scrapes. please let me know what it is. thank you
tylerho is offline   Reply With Quote
Old 03-11-2011, 06:34 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Looks like a power steering or oil leak. How's the level of fluid Iin the power steering reservoir? Try cleaning everything with brake cleaner and look from which the leak originates.
Edit: which side of the car is the leak coming from? If the driver's it could be the transmission pan gasket.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 03-11-2011, 06:56 PM   #3 (permalink)
tylerho's Avatar
it is on the right side (passenger side). i looked at the multipoint inspection results which i forgot to look at, heres the a picture of the leaks they saw.
Old 03-11-2011, 07:24 PM   #4 (permalink)
Avy
Can you see if the valve covers are leaking? Is the front of the block covered in oil? Could also be the cam or cranks seals behind the timing belt.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 03-11-2011, 07:31 PM   #5 (permalink)
tylerho's Avatar
I don't see any oil on the front the engine, i'll check it an get back to you where the oil is coming from or what ever fluid it is.
