driver door handles broke and can't open door. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2011, 11:48 PM   #1 (permalink)
View james42519's Photo Gallery
3rd Generation driver door handles broke and can't open door.
i have 94 camry le and the inside door handle is broken up to the spring and the outside one won't work because the rod came off it i think. is there any way i can get the door opened to take the door panel off? can i get to the rod to open it by taking the bezel off the inside door handle? have no idea what to do.
sorry if this has been asked already
james42519 is offline   Reply With Quote
Old 03-12-2011, 06:29 AM   #2 (permalink)
View rhymz's Photo Gallery
i think u can get to the rod by taking the inside bezel off...just use a long nose pliers and pull on it and the door should open up...just make sure once opened u fix it b4 locking it...
rhymz is offline   Reply With Quote
Old 03-12-2011, 08:04 AM   #3 (permalink)
ok thanks i will see if i can do that.
Old 03-12-2011, 03:35 PM   #4 (permalink)
iTrader Score: -1 reviews
View Eric N's Photo Gallery
Open the passengers door. Reach over, open drivers door from inside.
1994 LE sedan & 1996 DX coupe....with a bit of SE thrown in there
Eric N is offline   Reply With Quote
Old 03-12-2011, 05:23 PM   #5 (permalink)
i said the inside and outside handles are broken.
Old 03-12-2011, 05:33 PM   #6 (permalink)
Ah, i misread. thats unfortunate. lol.
Old 03-12-2011, 07:20 PM   #7 (permalink)
vincentfox's Avatar
View vincentfox's Photo Gallery
Search on youtube for "camry 1992-96 door panel removal" you will find some videos.
Remove one screw and pop it loose. Make sure you use the trick there of popping the two plastic latches using a screwdriver. If you just PRY it after removing the screw you will probably damage the bezel.
Once you get the bezel open assumedly you should be able to yank on the rods to open it and then finish the job. If it's the driver door and you have power windows I'd replace the window motor/regulator while you're in there. Mine needed it recently and it's only 1997. It's enough of an annoyance to me to open up a door and start working that now I would lean towards service everything at once that I can reach. As opposed to the way I did do it which was open it all up FOUR TIMES as each of those broke within a year:
1) Mirror replacement
2) Inside door handle
3) Outside door handle
4) Window motor & regulator
vincentfox is offline   Reply With Quote
Old 03-12-2011, 07:37 PM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
^ wow, youve had some bad luck. i wouldnt replace anything besides the handle.
i would do as others suggested. remove the trim from around the inside handle and gain access to the pull rods.
Old 03-12-2011, 07:48 PM   #9 (permalink)
ok thanks. i seen the video before but didn't know if you could get to that. i am not replacing more then needs to be because i really don't have that money.
Old 03-12-2011, 08:05 PM   #10 (permalink)
Have vicegrips? you could try to jam them on whats left of the interior handle and try to open it?
Old 03-12-2011, 08:11 PM   #11 (permalink)
that would work but there is nothign left of the handle. it is broke past the spring. you can see it.
Old 03-12-2011, 08:16 PM   #12 (permalink)
Diablo
View GaviN's Photo Gallery
Handles are like 10 bucks on Ebay. My cousin literally buys both interior and exterior door handles on a monthly basis. His little sons stay popping them on his 94, lol. I bought one for 15 bucks shipped about 3 yrs ago and its still holding up..and it was already painted black
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 03-12-2011, 08:20 PM   #13 (permalink)
yeah that is not the problem. i was just having trouble getting the door opened to change them.
Old 03-12-2011, 08:36 PM   #14 (permalink)
Diablo
^^Ohh. I used to have an 83 Sentra with that same issue about 12 yrs ago...I just removed the door panel and played the rod game for almost 2 yrs, lolol. The good ol days!!! That worked until the rod actually broke and eventually the car caught on fire (no relation to the door issue) and that was that, lol.
Old 03-14-2011, 03:11 PM   #15 (permalink)
thanks. i got the door opened with a flat head screwdriver. moved the back inside door handle to the front too and will see about changing the outside when it is not raining. the hardest part was taking the bezel off the handle and the clips on the rods.
