95 Camry only one washer spraying - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2011, 12:16 PM   #1 (permalink)
View brandoncallah's Photo Gallery
The windshield washer on the car only has good pressure spraying out of the passenger side nozzle.
What I have done:
Replaced the tubes to both of the nozzles, replaced the nozzles, and replaced the sprayer motor.
The first sprayer on the passenger side works great.
The one of the passenger side barely has any pressure.
The tube seems to be perfectly clear, it's new.
Any ideas?
brandoncallah is offline   Reply With Quote
Old 03-12-2011, 10:33 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Disconnect the hoses from the sprayer nozzles and compare flow. Did you replace the connectors as well as the hoses? Are they equal lengths? If there's some type of Y or T-splitter, is that part okay?
'07 Honda Ruckus Big Bore
Old 03-13-2011, 01:00 AM   #3 (permalink)
scarface305's Avatar
View scarface305's Photo Gallery
I had the same problem. Ends up that the white flies in the tree that I park my car under were emitting some sap sticky material and clogged the sprayer. Had to buy two new sprayers from the dealer.
scarface305 is offline   Reply With Quote
Old 03-13-2011, 09:43 AM   #4 (permalink)
I will give it a shot and double check the T splitter. Will update after I check it out.
