Hello new guy here. After searching through the forums I couldn't find the answer to my problem. So I'd thought maybe you guys would help me out.
My mothers 1999 Toyota Camry 2.2L today wouldn't start. Before the car would start but it would die right away. So every time you start it, you would have to rev on the gas petal to keep it going until the car warmed up and then it would run but at a very low RPM. It kept getting worse and worse until it would not start no more.
Note: We live in Alaska so it's pretty cold outside.
The car did have CEL on. I got it scanned yesterday and got the code PO172 running rich. I know people have said check the MAF but I don't think the 2.2L V4 has a MAF. Any ideas on why the car is running rich and what I could do to get it running? It's our only vehicle so I need it running ASAP.
Can't a vacuum leak create starting issues like this?
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Do the 99's have an EGR? If so sticking open EGR will cause stall at idle and maybe run rich code trip??? If clogged CAT it would have to be really, really clogged to prevent starting, problem would more than likely occur at speed. If it's that clogged then do a vacuum test on engine and it will show up pretty clearly.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Using an ohmmeter, check that there is continuity between the switch terminals when the coolant temperature is above 94°C (201°F). Using an ohmmeter, check that there is no continuity between the switch terminals when the coolant temperature is below 83°C (181°F). If continuity is not as specified, replace the switch
__________________ It worked fine until I fixed it!
