I just did an oil change on my V6 2000 camry with Mobil 1 Synthetic oil. I by mistake used one quart of 5W20 with the other 4 quarts of 5W30. Do, I have to redo this as I put a quart of 5W20 by mistake.
thanks
Changed the oil in a '00 camry four for the first time today and using three quarts of regular 5w-30 and one of 10w-30 -that's what I had new. I used an oem filter (the old filter came right off) the new filter is the taller of the two I’ve seen that fit the 5s-fe engine. The drain plug I found on the on the oil pan was brass-knurled with the bolt head directly beyond that... It took a 7/8"" socket to loosen and also wasn’t on too tight. The oil in the filter made somewhat of a mess on the block above and below, but that minor snafu cleaned right up. So ya, as long as yer gettin' fresh oil and filter in and on there, I highly doubt you'd have any type of problem.
