1997 camry 2.2 4 cylinder am2 fuse blowing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2011, 07:19 PM   #1 (permalink)
View LARRYSTUTTS's Photo Gallery
My am2 fuse blows when i try to start the engine. I was sitting idle for about 5 minutes with the engine running and the next thing you know the motor dies. Try to start it again but will not even turn over. I started checking fuses and found the am2 30amp fuse under the hood had blown. I replaced it turned the switch to on fuse still good the sec i turned the key to start the fuse blowed. I tried this 3 times it blows everytime in the start position. This camry is a 1997 4 cyl 2.2 litre. Can someone help me with this problem?
LARRYSTUTTS is offline   Reply With Quote
Old 03-13-2011, 07:26 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Several thing that can cause this, but the most likely is a bad capacitor in the distributor. You can verify this by removing the connector and see if it blows the fuse. Try that and post back.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 03-13-2011, 08:09 PM   #3 (permalink)
My camry has the electronic ignition system, and does not have A distributor. Is there anything else it could be?
Old 03-13-2011, 09:23 PM   #4 (permalink)
71Corolla's Avatar
Right, ignition coil, or coils in your case there should be two of them. Pull the connectors and try a new fuse, also look for frayed/damaged wires.
Old 03-13-2011, 09:28 PM   #5 (permalink)
Ok, I have tried unplugging the two coil packs but fuse still blows.
Old 03-13-2011, 09:30 PM   #6 (permalink)
71Corolla's Avatar
Unplug the wire going to the starter solenoid, try that.
Old 03-13-2011, 10:17 PM   #7 (permalink)
Unplugged that wire. Still blowing the fuse....Looks like this is going to be a headache..
Old 03-13-2011, 10:57 PM   #8 (permalink)
71Corolla's Avatar
To test for a short, first pull the negative battery lead, then the positive. With the AM2 fuse removed, look for a short to ground on the output side of the fuse. Do this with the key turned to the start position (get someone to hold the key). If you see a short, you will need to isolate where the short is exactly.
To find the "output" side of the fuse, check for continuity on the fuse terminals and the positive battery terminal. When you find continuity, the output side is the other terminal.
Old 11-03-2011, 05:55 PM   #9 (permalink)
114 Camry's and Counting
View The Camry Man's Photo Gallery
2nd Generation AM2 FUSE 30amp blown FIXED :)
AM2 Fuse 30 amp fuse 87-90 Camry
hey guys... I found after checking the wiring harness that the wire going to the fuel injector for #1 cylinder was caught under the valve cover
The owner said YES! he just replaced the VC Gasket Last weekend (Just before the problem started happening) ..
Maybe not your problem but it now RUNS AND STARTS PERFECT
Life Lessons Repeat ...... Ignoring them only causes you to experience them over & over!
The Camry Man is offline   Reply With Quote
