Originally Posted by DrkSkinKoolie
is there a diy step by step on how to remove the cables itself ?
i can make you a quick one...
-begin by removing the pins on the transmission's shift arms and slide the cables out of the pins
-remove the cable locks by pulling/gently twisting them
-jack the front of the car up on jackstands and remove the 2 10mm bolts that holds the outer shift cable grommet in place to the external firewall
-now get into the car and pull the shift boot trim
-remove the lower center dash trim part (the one with thw ashtray (dont remember where the bolts are but they should be 10mm)
-pull the capet on the passenger side so you can have a look at the firewall
-you will now see a similar grommet to the one on the other side of the firewall. to remove the 2 10mm bolts that are quite difficult to reach i highly suggest using one of those little ratcheting box end wrenches
-once you finally get the bolts out of the grommet unbolt the shifter and disconnect the cables from it
-then just pull the cables through the firewall and reinstall new ones !
if you have any question just ask!
