98' Toyota Camry...coolant backing up in coolant reservoir
My 1998 Toyota Camry LE was leaking coolant from the water pump and coolant was backing up in the reservoir so I had it replaced along with the radiator. Now there is no leak, however, the coolant from the radiator, is still backing up into the reservoir. I took the car back to the repair shop, but they can not find any leaks at all and the car will not run hot. Why is the coolant backing up in the reservoir instead of staying in the radiator. I have to put about one cup of coolant in the radiator daily before it fills to the top. One day when I took the radiator cap off the coolant in the reservoir spittled out of the reservoir through a hole on the lip on the reservoir...I don't think that hole is supposed to be there. I should be a mechanic...how come they didn't notice this opening on the that lip.
