Originally Posted by Hobo
OK, I followed the tutorial and cleaned the thottle body & spray a lot of the cleaner into the hole that goes to the IAC (Idle air control valve).
Didn't help.
Here are the symptoms: when the car is cold it idles very smooth in park & neutral.
It it's in drive and I have my foot on the brake the car vibrates.
After I drive the car a while and it warms up the car starts to sputter when in drive with the foot on the brake. The tach jumps around between 500 & 1000 rpm. If I put it in neutral the tach jumps to 1000 rpm and idles smoothly but after a couple of seconds the tach starts to drop to around 800 rpm and the car starts to sputter again and the tach jumps around.
I can rev the engine and it revs real smooth.
Is this a bad IAC valve?
Tach jumping sounds like a vacuum leak. Check the condition of the PCV Valve and the rubber tube that connects to the Intake. If its cracked, replace it. A new PCV Valve will run you about $5.00 - $10.00.
Grab the throttle body cleaner and spray it all over the intake manifold and behind the valve cover (covering the injectors). See if it idles up or bogs down.
If no progress, check the Fuel Pressure before the Filter, and also with the fuel filter installed. Check the condition of the fuel pressure regulator also.
