toyota camry fans will not turn on please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2011, 11:18 AM   #1 (permalink)
View nemesishadow's Photo Gallery
i have a problem with my cooling fans not coming on my 2001 camry 4 cyl it all started when i was changing my leaking radiator since then i have changed the thermostat, cooling temp switch, radiator, and cap and flushed system out but the fans still dont come on i know the ect sensor works cause it shows the car getting hot all parts bought were toyota brand parts and i also ran a wire from the battery to the fans and both fans work so what can be the problem
nemesishadow is offline   Reply With Quote
Old 03-15-2011, 11:35 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Engine? Year?
'07 Honda Ruckus Big Bore
Old 03-15-2011, 11:43 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
fues, relays good?
not that hard to check just open up the fuse box and find the one for the fans, also try swapping the relays
^ and leaving it that way!
Old 05-31-2011, 12:29 PM   #4 (permalink)
View JoeyS's Photo Gallery
Did you ever find the fix for this problem? I have the exact same car doing the same thing as yours. Fans don't come on. Checked all fuses and swapped relays from another working car.
Thanks
JoeyS is offline   Reply With Quote
Old 05-31-2011, 02:03 PM   #5 (permalink)
2002,5SFE
View houra's Photo Gallery
1. CHECK COOLING FAN OPERATION WITH LOW TEMPERATURE (Below 83°C (181°F))
(a) Turn the ignition switch ON.
(b) Check that the cooling fan stops.
If not, check the cooling fan relay and ECT switch, and check for a separated connector or severed wire between the cooling fan relay and ECT switch.
(c) Disconnect the ECT switch connector.
(d) Check that the cooling fan rotates.
If not, check the fan main relay, cooling fan relay, cooling fan,
fuses, and check for short circuit between the cooling fan relay
and ECT switch.
(e) Reconnect the ECT switch connector.
2. CHECK COOLING FAN OPERATION WITH HIGH TEMPERATURE (Above 93°C (199°F))
(a) Start the engine, and raise coolant temperature to above 93°C (199°F).
(b) Check that the cooling fan rotates.
If not, replace the ECT switch.
houra is offline   Reply With Quote
Old 05-31-2011, 02:05 PM   #6 (permalink)
2002,5SFE
INSPECT ECT SWITCH
(a) Using an ohmmeter, check that there is no continuity between
the terminals when the coolant temperature is above 93°C (199°F).
If there is continuity, replace the switch.
(b) Using an ohmmeter, check that there is continuity between
the terminals when the coolant temperature is below 83°C (181°F).
If there is no continuity, replace the switch.
(the ECT Switch location is on the lower radiator cover, near the drain plug)
The Following User Says Thank You to houra For This Useful Post:
JoeyS (06-02-2011)
