few questions about camry 1999
i have a toyota camry 1999 xle v6 and i have a few things to change and wanted to know if they will fit/work without any problems and what is right and what is wrong, what i should get and etc..
question 1:
I have 16" mags but the problem is that when i run it on the tire calculator the 16" tire profile suppose to fit for camry 2001 doesnt fit for mine, apparently it slows down by like 0.753% (tire profile 205/60/16)
but when i put 215/55/16 i am just perfect by 0.710% too fast but i have heard i would need spacers for it cause it would rub, is this true?
then also i have the other tire profile of 205/55/16 it will be 2.487% too fast but will it affect anything since it is a bit smaller?
i want advice from the people who have camry 1999 v6 and put 16" mags on their cars, i want to know what profile would you guys suggest and have tried without any problems..
question 2:
my car has a transponder (anti-start/demareur or otherwise known as kill switch) i believe i would need a bypass inorder to install remote starter on.. is that correct? which goes towards my next question, when i bought the car, there was no transponder key, but i have the 4 digit code to make a transponder key, is there any way to install remote starter without transponder key and does any one know how much locksmith charge for cutting and programming the key in montreal? (also if possible toyota price as well? because i called toyota and they said i have to replace the system, which is expensive)
question 3:
i have to replace my car battery, can i buy any car battery and install it? or is there a specific one i need to buy? i was thinking about going to canadian tire or walmart to get a battery or possibly costco.. so any suggestions you guys? (by the way i live in canada, and we have cold winters that are like -30 degrees celcius sometimes even -35 with windchill)
Toyota Venza 2010 AWD v6
OEM HID + 6000k D4S Bulbs
XM Platinum Series H11 8000k Digital HID
Toyota Camry 1999 XLE v6
XM Platinum Series Bixenon 6000K 55w Digital HID
