key turns nothing happens - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2011, 09:37 AM   #1 (permalink)
View JPS4's Photo Gallery
I’ve got a 1993 Toyota Camry wagon with 223,000 miles on it. Leaks a bit of oil, 2200 cc engine. I’ve been having vexing electrical problems to do with starting the car. 9 times out of 10 it starts up fine. But that one time out of 10, you turn the key and nothing happens, no click, no starter turning, nothing. For a while I thought it was the starter and I used to hit the starter with a hammer, but finally I replaced the starter and the problem keeps recurring. The alternator is new, as is the distributor, not just the cap, but the whole shebang, coil, rotor, etc. . Batttery is new. Timing belt recently replaced. One point that could be related is that not long ago I went to jet wash the engine to degrease it, and didn’t cover the alternator and that precipitated blowing the alternator and needing to replace that which I did. Perhaps something else got wet? It’s as if sounds like something is sticking, maybe a relay, or something in the ignition switch? I’d be grateful for any ideas.
JPS4 is offline   Reply With Quote
Old 03-17-2011, 09:47 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
I did a search for you...the link below may help
camry wont start or crank on one click sound
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 03-17-2011, 10:09 AM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
5sfe Starter Repair :
DIY: 5sfe Starter Repair
Neutral Safety Switch Cleaning :
DIY: Neutral Safety Switch Cleaning
If you diagnose / clean both of these and still have a problem, I would look into removing your ignition and cleaning / replacing it.
Old 03-17-2011, 03:14 PM   #4 (permalink)
View wave180's Photo Gallery
Ignition switch, it happened to me before on my Accord.
wave180 is offline   Reply With Quote
Old 03-17-2011, 05:09 PM   #5 (permalink)
Turk
View blumonster's Photo Gallery
Clean the battery heads, rust/debris may cause an intermittent no-start.
Also make sure the battery cables are very tight on the heads.
blumonster is offline   Reply With Quote
Old 03-17-2011, 11:11 PM   #6 (permalink)
View genie86333's Photo Gallery
Loose/corroded battery cables have caused this for me on my Camry.
Had the same problem with a Buick, strangely caused by a failing headlight switch.
genie86333 is offline   Reply With Quote
