93 Camry-Need Your Help, Please!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2011, 10:38 AM   #1 (permalink)
View mirandajohnson's Photo Gallery
USA 93 Camry-Need Your Help, Please!!!!
I have a 93 Camry LE 4cyl that wont start sometimes (it seems like when it's warm). I have replaced the fuel pump, distributor cap and rotary button, and coil. The car usually starts up sometimes but won't start after ran a lil bit. It is getting fire but just cranks and wont start unless i spray starting fluid in the air filter. When it does run it runs great, no missing or anything....Seems like an easy fix but it keeps costing me money, any ideas? Thanks
mirandajohnson is offline   Reply With Quote
Old 03-17-2011, 11:34 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Since it fires when you spray fluid into the Throttle Body it starts you have a fuel issue. Hook a fuel pressure gauge after the filter and monitor the fuel pressure. If its low, Try to disconnect the Fuel filter and Pressure check the line running from the pump. If its normal PSI, change the filter. If its still low, drop the tank and pull the pump out and check for blockage at the fuel pump sock. If thats clear, check the wiring running to the fuel pump.. Make sure the (+) wire has 12V+.. While monitoring the voltage wiggle the wires around and see if it drops to 0V. if it does, repair the wiring. If that's good, but you still do not have fuel pressure, change the Fuel pump with a new one. (These usually almost never go bad the entire life of the vehicle but it does happen). Generally the most common issue for fuel pressure problem is a clogged fuel filter or fuel sock on the pump.
Also check the main fuel line for leaks (rotted areas .. wet areas) .. if its wet or shooting out, your loosing pressure out of the line and you should replace or repair the line.
You can also try to disconnect the fuel line at the Filter and at the Tank and blow compressed air through the line and see if air comes out the opposite side. if it doesn't, your fuel line is clogged somewhere from the tank to the engine bay
The Following User Says Thank You to Mister_Perkins For This Useful Post:
mirandajohnson (03-17-2011)
Old 03-17-2011, 11:44 AM   #3 (permalink)
Thanks Mr. Perkins!
I have replaced the fuel pump and sock but not the filter because when it does run, it doesn't miss or anything...I will try the filter first. Thanks again!
Old 03-17-2011, 12:34 PM   #4 (permalink)
More than likely your going to find that after the car is warm, your fuel pressure regulator is failing ( allowing pressure to back-feed back to the tank ) and empty out your Fuel rail. I would replace / test the fuel filter and also replace / test the regulator. the regulator is on the passenger side of the fuel rail (left). Its easier to access if you remove the valve cover.
