Bought A Camery!!! What do you think.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2011, 07:41 PM   #1 (permalink)
View cashmoney13's Photo Gallery
Ok it's a 94 , with the 2.2 in it 97 grand on it. Interiors nice, but needs
Tires, front fender. And the water pump housing cracked
Got it for 400 dollars
What do you think?????
cashmoney13 is offline   Reply With Quote
Old 03-17-2011, 07:49 PM   #2 (permalink)
View DarkSideMoon's Photo Gallery
Is it leaking coolant? If so, you'll want to check for any overheating damage.
DarkSideMoon is offline   Reply With Quote
Old 03-17-2011, 07:55 PM   #3 (permalink)
yes it is leaking coolant... how would I go abouts checking to overheating damage???
THANKS
Old 03-17-2011, 08:02 PM   #4 (permalink)
By the way, 400 sounds excellent. Although you will definitely need to take care of that coolant leak. Make sure you don't overheat it while you're getting it fixed. If the engine runs fine I'd just check the head gasket. Look for white smoke when you start the engine, as well as white gunk/whitish oil on the oil dipstick. If you want to really get in depth you could perform a leakdown test or a coolant hydrocarbon test.
Old 03-17-2011, 08:10 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check the cylinder compression for starters, if it checks out (min 142psi, normal around 172psi, up to 220psi is not unusual on dirty engines)
If you decided to get it repaired, do a complete timing job with all gaskets and seals while replacing the WP housing (and pump itself).
what bothers me about a cracked WP housing is why it happened in first place ... and I can actually think of only 1 reason and you are not gonna like it. there most likely was water only in cooling system during Winter, so when it turned into ice (and expanded) as temperatures fell it cracked the housing... what gives ... possible HG and radiator damage from ice.
once WP housing is fixed, do a cooling system pressure test (with all spark plugs removed) and see if all holds and there is no coolant squirting from anywhere (like cylinders or side of engine block).
how is your oil looking like now? if white & milky then the HG is blown.
Old 03-17-2011, 10:10 PM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Better hope that if the motor did freeze, it didnt crack the water jacket inside the motor. Check the condition of the freeze plugs. if they are weeping you may have internal damage to the motor. Still cant beat the price of $400.00 . If the motor is bad, you can replace the motor with a good one and have a reliable car for years and years with proper up-keep
Old 03-17-2011, 10:14 PM   #7 (permalink)
Safari Wagon's Avatar
Gameroom cash: $213650
View Safari Wagon's Photo Gallery
I guess I'll be the one to say it... it's Camry....
It will be a great deal if you won't have to replace the engine. If you do, it will be an okay deal, so you win either way.
Enjoy your new Camry!
Safari Wagon is offline   Reply With Quote
The Following User Says Thank You to Safari Wagon For This Useful Post:
CamryWilly (03-18-2011)
Old 03-17-2011, 10:19 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
I agree, even if motor is on its last legs then the swap would be a good option. OP has nice car's body and no signs of trans failures, so it might pay off for long years to come... if properly maintained.
Old 03-17-2011, 10:23 PM   #9 (permalink)
vincentfox's Avatar
View vincentfox's Photo Gallery
You should have posted at least one little picture.
vincentfox is offline   Reply With Quote
Old 03-18-2011, 09:15 AM   #10 (permalink)
Thanks for all the help guys, now what exactly do you mean by weeping
And where are the freeze plugs located
Sorry Im a newbie haha
Old 03-18-2011, 09:59 AM   #11 (permalink)
Weeping means leaking antifreeze around the outside edge :
There are 4 on the back side, 4 on the front, and one on the timing side, and one on the rear main seal side.
all together 10.
Pictures:
Back side of motor :
Front side / Rear Main Seal Side. As you can see on the picture, where the motor is mounted, there is a shiny freeze plug located just behind the mounting plate
The Following User Says Thank You to Mister_Perkins For This Useful Post:
cashmoney13 (03-18-2011)
Old 03-18-2011, 10:15 AM   #12 (permalink)
Thank so much for the pics, now when I run it it makes sort of a whining sound is that becouse of the cracked wp
Or could it be a leak in a seal
Old 03-18-2011, 01:08 PM   #13 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Any number of things could cause the whining sound. Please read through the wealth of info on TN.
Later you can post specific questions about diagnostic tests that members will recommend you to perform on the engine. If possible grab a manual for your camry. Read up as much as you can.
Trust me it will be one fun ride here on TN
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 03-18-2011, 08:26 PM   #14 (permalink)
Old 03-18-2011, 08:27 PM   #15 (permalink)
its kind of dark but I will get some better pixs tomarro..
