92 Camry 3VZ-FE shoots fuel out exhaust - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2011, 07:45 PM   #1 (permalink)
ex tech, new driver
View zorcy's Photo Gallery
Driving down the highway and a cloud of white rolls out the back. It has been over heating, so I was thinking the head gaskets. Replaced it, started up and still has fuel cloud out the back. Searching the net over and found next to no answers. I can run out 1/4 tank of gas in 5 minutes. Gas puddles out the tailpipe and runs out an exhaust leak under the engine. Had a bad O2 sensor and replaced it. I could not get any codes. I forced it to give me a 55, knock sensor. I don't see it giving me this issue. Disconnected all the injectors, 1 at a time and 2 at a time. It would not stop the gas, but would run a little rougher each time. All plugs and wires were changed with head gaskets. Tried to advance the timing in case i was just to far back. It will not stay running without help, once it warms up, so I can not correct the timing. The only pin out for the ECM I could find was the 1MZ. Not even close. I was going to jump the left knock sensor to the right (error code). I also opened the ECM to see if there was any physical damage or shorts. Nothing there, noticeable. I have a good vacuum (by touch, gauge is missing) at the fuel pressure regulator. When I first start, seems smooth, very little white smoke but still smells gas.
Any advice or suggestions would be great. I have given up most my tools when I left the business in 91. I work in an office and have just the essentials. Any shortcuts or work around are best for me.
93 Camry V6 3.0 224K+ miles, at least 3rd hand gonna tinker on this for a while
zorcy is offline   Reply With Quote
Old 03-19-2011, 09:57 AM   #2 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Here's some thoughts:
Unregulated fuel pressure (i.e. fuel pressure regulator fault)
Shorted injectors
-> Injector
-> ECU ground control transistor/IC (bad ECU)
I have 93 3VZ wiring diagrams. PM me your email address and I'll share it with you.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Tags
1992, 3vz-fe, camry, cloud, fuel
