Need a little help verifing fill plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2011, 09:04 PM   #1 (permalink)
View scalelar's Photo Gallery
I have a 95 camry 4 cyl w mt. I'm giving it to my son-in-law and we were replacing the driver side drive axle. Alot of fluid poured out when we got the drive axle out.I'm trying to verify where the fill plug is located. I have a Haynes manual but it only has a drawing and it isn't very detailed so I'm posting a pic with an arrow to what I think is the fill plug. It just seems a little low to me.
Thanks for any help.
scalelar is offline   Reply With Quote
Old 03-21-2011, 08:02 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The fill plug is on the Back side of the transmission (towards firewall).. Its in a higher position
Old 03-21-2011, 07:25 PM   #3 (permalink)
Thanks Mr Perkins. Think I found it. Big wiring harness over the top of it. Hope thats it anyway.
Old 03-21-2011, 08:32 PM   #4 (permalink)
On second thought I don't think I found the filler plug. What I found was the breezer plug. Guess I'll look some more.
Old 03-21-2011, 09:07 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Look at where you had the arrow. Should be a 24mm plug. The drain should be 17mm below the left halfshaft.
When was the clutch fluid last changed? This is a good time to do it too. Valvoline Synthetic brake fluid from Autozone or Castrol GT LMA from Pep Boys (both are low moisture activity fluids).
Old 03-21-2011, 09:37 PM   #6 (permalink)
its a manual transmission fellas. Those are Automatics
Old 03-22-2011, 07:34 PM   #7 (permalink)
Csaxon
Thanks for the reply. That looks alot like the plug in my pic. If it is it is hard to believe it would hold 2.7 quarts. I'll look again tomorrow. Thanks again!
Old 03-22-2011, 09:41 PM   #8 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
