Spark plugs ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 11:40 AM   #1 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Spark plugs ?
Anyone using single ground electrode plugs in 2nd Gen Camry 4cyl ?
I'm guessing they are hotter than duals (stock ?) which should be okay but I've heard some Toyota's are finicky ......
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 03-21-2011, 12:59 PM   #2 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
I was tought to use the OEM part number.....
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 03-21-2011, 02:14 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Not sure what you mean by "hotter"? Better spark??? Not as far as I know.
I'd say single platinum plugs will last a bit less long than dual. So it's a matter of preference. On a 4 cyl engine where they're easy to replace, I'd be inclined to go with single. But that's just my opinion.
You might be thinking of some of the V6 engines Toyota makes where they have a waste spark system. That is, there is one coil for every 2 spark plugs which fires both plugs at the same time, "wasting" the spark in one of the cylinders. These wear plugs out faster because they fire twice as often as necessary.
BMR is online now   Reply With Quote
Old 03-21-2011, 08:11 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Look up the plugs on NGK's web site.
http://www.ngksparkplugs.com/product.../iridiumix.asp
The car can use NGK Iridium-IX. These are excellent plugs.
Iridium IX BKR6EIX-11
3764
