1997-2001 Camry Ride height specification - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 02:36 PM   #1 (permalink)
View GopherT's Photo Gallery
I have searched high and low to find the Toyota specification for ride height on a 1999 Camry (USA - 4 cylinder w/14" steel wheels).
I am just trying to see how bad my springs are and if they need to be replaced. Actual height specifications and where to measure (Front and rear) would be greatly appreciated.
Currently, I have OEM struts and just under 60k actual miles. The struts seem fine, just the springs seem to be sagging - more in front that back.
Thanks for your help,
-GopherT
GopherT is offline   Reply With Quote
Old 03-21-2011, 04:29 PM   #2 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
this is from wikipedia (how accurate it is idk)
Wheelbase 105.2 inches (2,672 mm)
Length 189.8 inches (4,821 mm)
Width 70.1 inches (1,781 mm)
Height 55.4 inches (1,407 mm)
Curb Weight 3,00 pounds (1,361 kg)
http://en.wikipedia.org/wiki/Toyota_Camry_(XV20)
adalex is offline   Reply With Quote
Old 03-21-2011, 04:40 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
with springs youll notice a very sloppy ride before a drop in ride height. so how is it? is actual miles on the struts or the car (springs)? are these struts OEM spec or toyota OEM?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-21-2011, 05:36 PM   #4 (permalink)
I used the vehicle height as an estimate. Measuring to the roof says I am about 3" low. I was having trouble believing the car has sagged that low. I am mainly having trouble deciding if the rear needs springs or just the front (an obvious lean forward when looking at the car).
The car was barely driven in the past 8 years - it has 60,000 total miles. The struts are OEM from when the car was new.
I was hoping there was a simple list of measurements commonly available from the service manual (e.g. 10" from ground to lower strut bolt; or 5" from top of wheel to high point in fender).
I haven't looked in a service manual for about 15 years and, now that my son started driving, I have renewed interest in working on cars (with him). Anyhow, I do remember seeing ride-height specs like this in factory service manuals for Fords (Pinto and Mustangs). It might be a thing of the past. Anyhow, thanks for your help.
-Mark
Old 03-21-2011, 05:54 PM   #5 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Front vehicle height:
SEDAN/COUPE:
Tire size Height
195/70-14 210mm (8.27in)
205/65-15 213mm (8.39in)
Wagon:
205/65/15 214mm (8.43in)
Measuring point:
Measure from the ground to the center of the front
side lower arm mounting bolt.
Rear vehicle height:
SEDAN/COUPE:
Tire size Height
195/70-14 262mm (10.31in)
205/65-15 267mm (10.51in)
Wagon:
195/70-14 272mm (10.71in)
205/65/15 277mm (10.91in)
Measuring point:
Measure from the ground to the center of the strut
rod mounting bolt.
Pvt-Public is offline   Reply With Quote
The Following User Says Thank You to Pvt-Public For This Useful Post:
GopherT (03-21-2011)
Old 03-21-2011, 06:13 PM   #6 (permalink)
Pvt-Public,
Thank you - you are the best!
-GopherT
Tags
1999 camry, ride height, springs, stock
