95 parts that capable with 96 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 06:08 PM   #1 (permalink)
View mk2mr2's Photo Gallery
Hi. I was looking for the rear wheel bearing and toyota only sold the whole assembly which cost 443 each. I cancel that. I have a 96 le 4 cyc non abs.
I found someone locally selling parts from a 95. Don't know if it's abs or not.
I was wondering what fits my 96. He can sell me the whole hub assembly for 30 each. I need new strut, but the car I don't think is worth new strut. Used strut yes. I am wondering what pieces I can get off the 95 that will work for me.
Thanks.
mk2mr2 is offline   Reply With Quote
Old 03-21-2011, 07:41 PM   #2 (permalink)
this is what I have.
92 Camry rear bearing vibration
what is the worest a rear bad wheel bearing can do or the chance of it seizing?
Old 03-21-2011, 10:00 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Your tire can fall off......
Old 03-21-2011, 10:05 PM   #4 (permalink)
Thanks. I don't plan on driving it until I fix it.
Any idea if this 95 would wheel bearing would fit? Struts?
Last thing is I will by from Advanceauto or autozone. I want to get to it this weekend, gas price is getting to high to be driving something like a 22r 4x4 on 32's.
Old 03-21-2011, 10:08 PM   #5 (permalink)
If you can find a salvage yard, you can pull the bearings off another car too. They are only held on by four 14mm Bolts. All you need is an extension, 14mm socket, and a ratchet. (This is if you have rear drums).
Pull the tire off, support the rear of car off the ground, remove the drum. Spin the hub around until you see the hole line up with the bolt (You should be able to see two bolts at a time). Remove all bolts by spinning and lining the hole up. Then simply remove, and re-install the new / newused one. Very very easy. You dont even need to remove the rear shoes!
( I believe the Rears for the Disc brakes are set up the same, but I haven't actually taken a look yet on my XLE )
95 and 96 should interchange. Only difference is one is OBD1 and the other is OBD2
Old 03-22-2011, 07:22 AM   #6 (permalink)
Sounds good.
Old 03-22-2011, 05:07 PM   #7 (permalink)
Gameroom cash: $303755
What I do when I have a question like this is go to one of the on-line dealer websites and check on the part for both years. Write down the part number(s). If they are the same, you have a positive answer.
Mike
