Salinas temp ranges from about 40 degF to 60 degF. I'd get Motorcraft
FL400S filter (similar to PureOne) and
Motorcraft 10W-30 synthetic blend oil (newest API SN GF-5).
High mileage engine oils typically have more detergent, seal conditioners, and are slightly thicker in their viscosity ranges. Mobil oils are fine, also consider Valvoline MaxLife oils.
I personally tend not to use those oils unless there are minor seal related problems or varnish that need cleaning. But others like the extra detergent and seal conditioner for similar amounts of money. YMMV.
The 99 V6 is a known sludge maker. I would stay with 3000 intervals.
Originally Posted by ty_99_V6_1mzfe
Wow the last post i put up exploded with a lot of suggestions of the oil filter and i decided to use the purolator pure one. What do you guys think about the Mobil Super High mileage 5w-30. heres a link what it it compared with
http://www.mobil.us/USA-English-LCW/...son-chart.aspx
I was at walmart and they had a lot of high mileage oil from different brands. I am very interested in the Mobil line up. How how should my drain intervals be if i do use this mobil super high mileage. Thanks. I have a 99 v6 camry
