Speedometer? - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 03-21-2011, 09:48 PM   #1 (permalink)
robertoduh's Avatar
View robertoduh's Photo Gallery
3rd Generation Speedometer?
My old cluster shorted out, and I bought one from a Camry with 218k miles.
The problem is that my friend was playing with the old one and pulled the needle out of the speedometer, and it messed it up
I need to put the old speedo back in since my car only has 107k. How can I recalibrate the old speedo so i can put it into the other cluster?
robertoduh is offline
Old 03-21-2011, 09:58 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
the only way I know to do it is to roll the numbers by hand. If you try to take the speedometer apart, the numbers will spread apart leaving a gap. Upon inspection, you will fail because they will know you tampered with the cluster. You can always find a camry with around the same mileage. Maybe a small amount more, and just install that.
How did he get the speedo needle off? Did it break the Metal post? Or just removed the needle? If the post is still there, just push the needle back on.
Mister_Perkins is offline
Old 03-21-2011, 10:03 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
You talking about the speedo or the odo? The speedo is easy to calibrate if you have a GPS. The odometer, much harder to change the reading, but it can be done.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now
Old 03-21-2011, 10:05 PM   #4 (permalink)
yeah thats the most efficient way to calibrate it. just remove the housing and install the cluster partially. Snap the surrounding in and keep the needle off. Once you get crusing .. Say 10 miles per hr on the GPS, ease the needle back on at 10MPH. stop. Retest at a faster speed. That's what I did on my car anyways
Old 03-21-2011, 10:41 PM   #5 (permalink)
robertoduh's Avatar
He pulled it off and stuck it in a different position. It jumps to 110mph when the ignition is turned on. He messed up the tach too on the old cluster but the tach isnt really that important.
How hard would it be to just remove and replace the odometer?
Old 03-21-2011, 11:02 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I'm going to hurt you. Watch my video series on cluster tech (link in sig). YES, you can swap speedos and tachs around. They just have to be from the same engined car.
'07 Honda Ruckus Big Bore
LynchburgCSI is offline
Old 03-22-2011, 01:06 AM   #7 (permalink)
robertoduh's Avatar
I know that. My question is how to swap the actual odometer over to the 218k speedo. The one that currently reads 107 is reading too fast and I don'tknow how to calibrate it and I don't have a gps.
Old 03-22-2011, 01:15 AM   #8 (permalink)
Freakin Scooters
Watch the videos please. PM me if you have a question. LynchburgCSI Video Series: Cluster Tech
Closed Thread
