Just wondered if anybody had the following problem & how they resolved it.
1995 Camry, 4 cylinder...
The car cranks like its brand new when you crank it up in the morning or anytime it hasn't been started in a couple hours. After warm-up, turn the car off and at next start-up the RPM'S drop so low that the engine tries to die (400-500rpms) It takes a moment or two for the RPM'S to adjust.
Can anybody suggest a definite solution ?
jim
Reason: edit
Idle Air Control valve. It's mounted under the TB, you probably could see the opening in TB leading to IAC valve. This valve is a sort of air bypass around the throttle plate, completely controlled by ECU electrically. If it's dirty, then idle speed is rough and sometimes shoots high when it should be low or vice versa, depending on how the dirty valve sticks.
might be worth checking and/or cleaning first. common trouble on gen3/4 camry.
other than that, how the car feels when driving? any maintenance history? any tune up done?
Yeah...I did spray some carb cleaner back there, but i may need to re-visit that as i ran out during job.
Car fells great when driving...could have a little better mpg...Has 260k on it...Had new distributor 10k ago...new plugs & wires then just because...(I may get buddy to check timing). Can the IAC be removed and cleaned to any good effect ?
"Can the IAC be removed and cleaned to any good effect ?"
Yes it can, but I would first try spraying throttle body cleaner liberally down in to the port in the base of the throttle body that leads to the idle air control valve. That usually cures the problem. If it doesn't, then you can go to removing the idle air control valve for further cleaning. Here's a good DIY on the cleaning process for the 4 cylinder 5SFE engine.
Removing and disassembling the IAC usually yields better results. The carbon on the bottom of the rotary valve is hard to clean off. Check this DIY too:
If the IAC doesn't improve it then check the engine coolant temperature sensor as well. It's the 2-wire thing on the water outlet pipe.
Originally Posted by JimBowNut
Hey Guys/Gals,
jim
The Following User Says Thank You to JohnGD For This Useful Post:
GOT'ER DONE !!! Thank You ALL for all the help !!! That Thing was crusted w creosote [it looked like]. looked like the inside of my wood burning stove !
Which method did you use; the on the car or the off the car method?
