I've been defeated! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2011, 04:34 PM   #1 (permalink)
View CBZED101's Photo Gallery
I've been defeated!
So today I set out to replace my lower control arm bushings on the passenger side of my '93. Should be an easy task, take off the tire, undo 1 bolt on the stabilizer bar, 1 bolt and 2 nuts on the steering knuckle, 2 bolts on the engine cradle, 1 bolt on the end, take control arm to have new bushing pressed in, and re-install. Figured it'd take me 2 hours max to do. Well, everything was going well until I got to the 3 bolts that hold the arm to the cradle. I spent 6 hours trying to get those damn bolts off to no avail. I used a cheater bar, an pneumatic impact wrench, a whole can of liquid wrench, a hammer and box-end wrench, and even tried using a torch to loosen the bolts. Nothing worked. So I ended up having to just put her all back together and admit defeat. So frustrating. Anyone know of anything else I could try to do to get the bolts off?
Also, something cool did happen though; while I was working on the Camry a Google street view camera car drove past. So, soon you'll be able to look me up on street view working on my Camry.
CBZED101 is offline   Reply With Quote
Old 03-22-2011, 04:44 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Ken's Off the Top of His Head Tips:
Heat the material that the bolt is going through, NOT the bolt itself.
PB Blaster. That's the only penetrating oil you should have for jobs like this.
'07 Honda Ruckus Big Bore
Old 03-23-2011, 01:13 AM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Heat and brute force!!!
Did you break anything? Sockets, ratchet, breaker bar? If no, then apply more heat and more torque. Use only quality 6 point sockets and keep fingers out of danger from being smashed, but honestly this sounds like you need both feet on a bar!
The 1MZ harmonic balancer bolt comes to mind. Split a socket open and cracked the 1/2" drive breaker bar drive (where the socket attaches), but in short it has factory loctite and its tite! Get mean with it!!!
73sport is offline   Reply With Quote
Old 03-23-2011, 09:33 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
When I did mine, I used a 3 foot long pipe on my breaker bar, and I had to brace my feet somewhere to get my back into it. They let loose with a "CRACK!!!" And mine isn't very rusty compared to some of the pics I see posted. Gotta love the high desert climate here (no humidity).
BMR is online now   Reply With Quote
Old 03-23-2011, 11:29 AM   #5 (permalink)
So far I didn't break anything other than a 19mm 6 point impact socket. Stripped it out almost completely. Didn't think it was possible. o.O I didn't have much room to fit a breaker bar on the 2 bolts on the engine cradle. I'll have to try again on my next day off...probably next Tuesday.
Old 03-23-2011, 01:45 PM   #6 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Put everything back with anti-seize grease too just incase you have to take all of this stuff apart in the future.
RichieRichJP is offline   Reply With Quote
Old 03-23-2011, 09:10 PM   #7 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
Putting both feet on a bar is dangerous - use leverage, torque = radius * angle, so a longer pipe is the way to go.
You'll get it with the pneumatic, just make sure your compressor should have a minimum of 5 scfm at 90psi and you should use either 3/8" or 1/2" air hose (less pressure drop). Check your pressure at your tool using a tee and pressure gauge to make sure there are no restrictions.
There are Ingersoll Rand 1/2" penumatic impact wrenches rated at 1100 ft-lbs for nut busting torque available for around $200. Harbor Freight also sells pneumatic impact wrenches that should be able to break 800 ft-lbs for less. Both are twin hammer designs and should be able to remove these with ease now that you have soaked penetrating oil for a few days,
SilverSoarer is offline   Reply With Quote
