i'm simply asking a question
my concern is described in details in another 40 page long thread
basically I'd like to have comparison with same engine/intake/injectors/sensors/ecu/trans/emissions model, because establishing common average values helps me decide on finishing off or continuing the major tune up (trying to get the fuel trims as low as I can without tearing the engine apart).
the difference between idle speed in Park/Neutral (more mechanically controlled) and Drive gear (mostly computer controlled) may reveal minor vacuum leaks or confirm they are gone.
also since I no longer have the paint mark on the throttle adjustment screw after numerous adjustments over the years, it's hard for me to know where is the spot the ECU wants most.
Originally Posted by 1steve
Are you having a problem or just curious? I don't understand your concern.
